idel problem
idel problem
I have a obdll gsr motor that is ideling funny. it was fine one day then the next it just started 2 rev up and down like to 1300 then drop back down. do you know what the problem is? it is not a vacuum leak and it is not my i-ac.
ob2 i believe they dropped the fitv and the iacv controlls the warm up also. I may be wrong though.... i would check my coolant for air, check the intake maniflod and throttle body for air leaks. check the sensors on the tb for air leakage also..
Re: (dc2_88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_88 »</TD></TR><TR><TD CLASS="quote">ob2 i believe they dropped the fitv and the iacv controlls the warm up also.</TD></TR></TABLE>
yes that is true
check the IACV, that is usually the cause of about 80% of idle problem cases
and as said, check all of your vacuum lines, and your throttle body gasket as well
yes that is true
