I can smell Gas in my oil....... Help
ok... 94 civic, Ls swap
Was smashing around for about 15 mins tonight.... check engine light came on.
Idle was at 1200, instead of the regular 750
Checked the oil.... and it was Way over the second dot (i always check my oil level)
I smell gas in my oil. Im guessing NOT good
Let it sit for 20 mins.... started it back up no check engine light, regular idle....Im changing the oil first thing tomorrow morning.
WHATS HAPPENING??? Thanks guys
Guest
Posts: n/a
Re: I can smell Gas in my oil....... Help (EGcivicBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGcivicBoy »</TD></TR><TR><TD CLASS="quote">ok... 94 civic, Ls swap
WHATS HAPPENING??? Thanks guys</TD></TR></TABLE>
why don't you at least check your CEL code?
Re: (4sd4dr)
Are you sure you smell gas in your oil? Its not from somewhere else in the engine bay? Were you on a even surface and did you wait a little while b4 you checked your oil?
Nukin
04-29-2018 09:36 PM
skUnK2jdm
15
12-22-2007 08:03 AM
