how to tell if fuel pump is going out? - Honda-Tech
Old 03-21-2003, 08:38 AM   #1
PatrickGSR94's Avatar
Default how to tell if fuel pump is going out?
Does it make any kind of wierd noises or anything if the fuel pump is on its way out?
PatrickGSR94 is offline   Reply With Quote
Old 03-21-2003, 09:16 AM   #2
Default Re: how to tell if fuel pump is going out? (PatrickGSR94)
I'm hearing a high pitched whine/hiss from mine, almost like alternator noise (I don't have any interior behind my front seats at the moment). Is this normal or should I be concerned?
Old 03-21-2003, 10:07 AM   #3
EPIC TUNING
E-Rok's Avatar
with no rear seats and a stock exhaust, you can easily hear the fuel pump. Its fine.
E-Rok is offline   Reply With Quote
Old 03-21-2003, 11:39 AM   #4
tilt's Avatar
there's a test you can do. I dont know the specifics for it but basically you take the fuel line and put a cup to it and measure the flow. For n seconds there should be x volume of fuel. If you are less than normal specs (look it up in a manual) then you know your pump isnt performing how it should be.
tilt is offline   Reply With Quote
Old 03-25-2003, 05:08 AM   #5
JimBlake's Avatar
Default Re: how to tell if fuel pump is going out? (tilt)
Quote:
... measure the flow...
You can also measure the pressure - usually that's a test for the FPR, but if the pump can't keep the pressure high enough, you'll see that.
JimBlake is offline   Reply With Quote
Old 03-25-2003, 08:27 AM   #6
Default Re: how to tell if fuel pump is going out? (JimBlake)
well I put my interior back in and I don't hear anything now. I guess it was normal.
fuel pump help 19992civichatch Honda CRX / EF Civic (1988 - 1991) 3 08-24-2007 06:10 PM
gsr fuel pump civroc95 Honda Civic / Del Sol (1992 - 2000) 1 03-29-2006 09:20 PM
NEED HELP ON FUEL PUMP WIRE COLOR? JDMbolo Honda Civic / Del Sol (1992 - 2000) 5 03-14-2004 12:53 PM
Fuel pumps grenthang Honda Civic / Del Sol (1992 - 2000) 3 03-25-2003 07:28 PM
Anyone parting out a 4th gen? boomslang Honda Prelude 0 03-03-2002 12:48 PM
Tags
1994, 2002, 94, acura, bad, civic, fuel, gas, goes, honda, hondat, inline, integra, kind, make, noise, pump, ruckus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
