how to stop polyurethane bushings from squeaking?! - Honda-Tech
Old 10-03-2002, 03:03 PM   #1
sutrusu's Avatar
Default how to stop polyurethane bushings from squeaking?!
someone said white lithium grease spray? any other suggestions? i hate that damn squeaking when i go up/down a driveway!
sutrusu is offline   Reply With Quote
Old 10-03-2002, 03:13 PM   #2
ILUVTEC's Avatar
Default Re: how to stop polyurethane bushings from squeaking?! (sutrusu)
If the grease doesnt help, then try to wrap the hardware that the bushing goes over/in with teflon tape(Example: If this was a rear sway bar bushing then just wrap the bar first with teflon tape, then install the bushing&collar). Only down side is that this requires re-installing them, so it can be time-consuming depending on what bushing this is. Enjoy
ILUVTEC is offline   Reply With Quote
Old 10-03-2002, 03:14 PM   #3
Redtail's Avatar
They come with the extra thick grease from the factory, maybe you can just buy a tube of that ****. Probably just put on as much as possble and re-lube all the bushings every 6 months or so.
cheers
Redtail is offline   Reply With Quote
Old 10-03-2002, 03:18 PM   #4
Fuuma0083's Avatar
Grease it up like a pot belly pig. Grease, Grease, Grease.
Fuuma0083 is offline   Reply With Quote
Old 11-04-2003, 06:42 PM   #5
IntEGNYC's Avatar
Default Re: how to stop polyurethane bushings from squeaking?! (Fuuma0083)
no ky jelly
lithium grease shoudl do the trick
IntEGNYC is offline   Reply With Quote
Are d16y8 water pumps supposed to squeak? InTheZoneAC Honda Civic / Del Sol (1992 - 2000) 1 04-10-2014 02:30 PM
clutch squeaking LandeZak Honda Civic / Del Sol (1992 - 2000) 2 09-09-2013 11:38 PM
Clutch Squeak problem, Master/Slave Cylinders replaced... still squeak.. Help? ychanus1 Acura Integra Type-R 8 08-06-2013 10:04 AM
weird engine squeak dtarvin Honda Civic / Del Sol (1992 - 2000) 9 05-02-2009 07:14 AM
HELP! susp. squeak after install? sjteg Acura Integra 2 06-13-2003 04:05 PM
Tags
bushing, bushings, grease, hate, how, lithium, polyurethane, squeaking, squeaky, stop, tape, teflon, to, urethane, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
