How to remove Rear engine mount? - Honda-Tech
Old 12-29-2006, 05:52 PM   #1
Sweetsystem's Avatar
Default How to remove Rear engine mount?
Guys I need some detailed info on how to remove the rear engine mount. I searched and everyone is vague. Do I have to remove my intake Manifold? Power steering rack?
Ultimately im trying to remove the engine. got everything else off except the mounts and intake mani.
Thanks
Sweetsystem is offline   Reply With Quote
Old 12-29-2006, 05:56 PM   #2
good luck. its a bitch to take it out.......took 3 guys to take my rear mount out and replace it with innovative. one guy jacking the motor up another guy watching from the top removing the bolt and another guy under the car trying to pull the mount out.
oh and it was our first time.
Fat Chick Magnet is offline   Reply With Quote
Old 12-29-2006, 06:15 PM   #3
* B A N N E D *
Default Re: (dc2rtek)
removing the intake maifold is the easiest way to go about it, then the mounting bracket for the motor mount, then the mount itself
here's a good write up on it: http://www.team-integra.net/fo...age=2
GRAF-FITI is offline   Reply With Quote
Old 12-29-2006, 06:16 PM   #4
i just took my intake off and it was easy to get to it.
Old 12-29-2006, 06:25 PM   #5
jdm_bones's Avatar
Default Re: How to remove Rear engine mount? (Sweetsystem)
Put your car on jack stands, come from under the car and hit with an impact gun. Make sure that you have a jack at the tranny ever so slightly pushing up on it and make sure that the crane is well attached to the engine...
jdm_bones is offline   Reply With Quote
Old 12-30-2006, 04:16 AM   #6
dc4teggiehatch's Avatar
took off tranny mount and left torque mount, loosend rear moutn bracket as well, jack stands on car and jack under motor, slowly raised/dropped til had enuff room (play) to wiggle out the rear mount. the hardest part is putting the bolts back in tight. you need alot of tools.
dc4teggiehatch is offline   Reply With Quote
Old 12-30-2006, 06:57 AM   #7
qfast817's Avatar
Default Re: (96teggiehatch)
its easyer when you remove the breather box, take out the rear l bracket
qfast817 is offline   Reply With Quote
Old 12-30-2006, 09:25 AM   #8
PrinceAli132's Avatar
Quote:
x2
Ali
PrinceAli132 is offline   Reply With Quote
Old 01-02-2007, 01:13 PM   #9
Thanks Guys. Completed all Maint. T Belt, Clutch, Tranny Fluid, Axles, front torque mounts, polyurethane engine mount inserts, All belts and hoses, Valve cover gasket, and Cam plug. Runs like brand new!
Side note: The Urethane inserts really firm up the engine, almost too much for my comfort level. I might be taking the two front ones out and just keeping the rear one in.
'02 motor mounts (how to remove rear motor mount) ConceptVBS Honda Civic (2001 - 2005) 4 04-17-2014 07:14 AM
Rear Crossmember Removal EF8DayDreamer Honda CRX / EF Civic (1988 - 1991) 8 05-11-2012 09:00 PM
engine block mount post removal Max McNasty Honda Civic / Del Sol (1992 - 2000) 4 11-10-2010 11:51 AM
90 teg removing engine mount. eXplicit Acura Integra 2 08-25-2005 04:41 PM
How are engine mounts removed? tzenisj Honda Civic / Del Sol (1992 - 2000) 2 01-29-2004 07:16 PM
Tags
94, accord, acura, bracket, car, change, engine, honda, integra, motor, mount, mounts, moutn, rear, remove, removing, teamintegra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
