How to remove cam gears? - Honda-Tech
Old 12-21-2003, 12:54 PM   #1
Default How to remove cam gears?
IS there a way to remove the cam gears off of the cams when they are not in the head?
LODOSS is offline   Reply With Quote
Old 12-21-2003, 01:41 PM   #2
JDM_Risa's Avatar
Default Re: How to remove cam gears? (LODOSS)
just go to http://www.c-speedracing.com find out its just like swapping cam all the procedures that involved ....and you don't have to take off the head........
JDM_Risa is offline   Reply With Quote
Old 12-21-2003, 01:46 PM   #3
JDM_Risa's Avatar
Default Re: How to remove cam gears? (GunMETAL_TEgRa)
you can do it that way unless u had a nice air gun set at TDC loosen the timing belt tensioner, pop off hte valve cover and take off the bolt holdin the cam gear then the safety keeper out slowly makesure u don't drop it into the timing bottom cover or you will be fucked.......then just reverse that and torque to specs.........
Old 12-21-2003, 01:54 PM   #4
SPOOLINVTEC
Guest
Posts: n/a
to remove cam gears, make sure your #1 cyl is top dead center(reason for this) 12mm wrench on the bolt and lossen...make sure you get the woodruff key its small so dont lose it. i hope your ready because do a timing belt install because you will have to redo the timing belt,because you will be removing it from the gears thats why you want to make sure its top dead center..i went through this headache when i changed mine because you WILL move the cams when you take off the belt because there is a load on the cam when its TDC and when you take off the belt the cams will move... just my info from someone who done it
Old 12-21-2003, 06:22 PM   #5
Sgt_Ox's Avatar
Default Re: How to remove cam gears? (spoolinvtec)
to loosen the 12mm bolt on the cam gear, I use a peice of paper, undo the camshaft bearing cap nearest the cam gear, put the peice of paper between the bearing cap and camshaft, bolt down the bearing cap then undo the bolt holding the cam gear in place. REMEMBER to remove the peice of paper when your done. Other wise you'll be in for a surprise. With that said it's always best to verify your work 2x's or even 3x's over.
Sgt_Ox is offline   Reply With Quote
Old 12-22-2003, 01:22 PM   #6
so in order for me ot take them off i would have to put them back on a assembled head? no way i can have something that cna jus torque it loose or a tool that locks it in place while unbolting the 12 mm?
Old 12-22-2003, 03:29 PM   #7
Sgt_Ox's Avatar
You can try to holding it inplace the and use an impact, however I'd suggest to retorque when it's on the head though.
Old 12-22-2003, 03:33 PM   #8
IN VTEC's Avatar
There are cam gear place holder tools, but they're expensive as hell from Matco or Snapon. I haven't found a reasonably priced one yet.
Instead, I just got an electric impact wrench for jobs away from the garage where I don't have a compressor.
They're 14mm bolts.
IN VTEC is offline   Reply With Quote
Old 12-28-2003, 09:50 PM   #9
SPOOLINVTEC
Guest
Posts: n/a
Default Re: How to remove cam gears? (IN VTEC)
i dont know where your cam bolts came form, but everyone elses is 12mm dude
Old 12-28-2003, 10:10 PM   #10
IN VTEC's Avatar
You should go back and check.
And, you can torque down the cam gear bolts after you tension the belt.
Old 12-31-2003, 04:56 AM   #11
i don't know what kind of cars you guys are talking about but if it's a B Series motor. it's a 14mm bolt.
DC2_9 is offline   Reply With Quote
Am I crazy or are these cam gears just defective 2kdrift Forced Induction 6 03-11-2016 11:11 PM
How do i change cam gears on the cams b20beast83 All Motor / Naturally Aspirated 7 09-02-2008 05:21 AM
help with cam removal speed_racer012 Honda CRX / EF Civic (1988 - 1991) 1 05-11-2003 12:18 PM
Removing bolt from cam gear Lyonel Tech / Misc 6 06-03-2002 07:51 PM
removing cam gears without impact wrench shingles Tech / Misc 10 12-24-2001 05:45 AM
Tags
1990, bolt, bseries, cam, camgear, camgears, gear, gears, h22, honda, integra, ot, remove, specifications, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
