How do you relieve a flooded(gas filled) engine?
I think my integra's engine is flooded because when I pulled out the spark plug, it smells like gas and has gas all over it. So how do I get the gas that's in the engine to ingnite so that the car would run. Right now the engine just cranks but doesn't start. Thanks
Re: How do you relieve a flooded(gas filled) engine? (TonyT)
I pulled the fuel pump fuse, cranked it with the gas pedal to floor.
It let in enough air to start for a moment, before it burned off the extra fuel and then stalled. Put the fuse back, started normal.
Re: How do you relieve a flooded(gas filled) engine? (StyleTEG)
simplest way, but not the smartest way is, take ur plugs out and start ur car, but dont run it!!! just turn it on for like 4 secs then cut it off. pretty cool as u see fuel flying into the air like a water sprout. put a towel over the valve cover if u dont wanna get messy. this has worked for a lot of people.
Re: How do you relieve a flooded(gas filled) engine? (DOHChi)
DOHChi,
When you say take the plugs out, how many plugs do I need to pull out? I'm assuming just one plug but I'm just making sure. Thanks.
Jomz0825
14
11-13-2015 01:34 PM
STEV3-O
07-24-2005 09:02 PM
nd94cx
09-21-2004 07:29 PM
