how do you move the ignition from the column to the dash in a 1996 acura integra
Old 07-12-2009, 06:36 PM
huckaboo's Avatar
Default how do you move the ignition from the column to the dash in a 1996 acura integra
iv tried to find posts for this and i didnt come up with anything if someone knows how to do it can you let me know because i really want to see how its done before i rip everything apart.
all i am trying to do is move the ignition from the column to the dash where the dimming **** is for the cluster...
Old 07-12-2009, 06:52 PM
Reject Papi
jhammond_82's Avatar
Default Re: how do you move the ignition from the column to the dash in a 1996 acura integra
have a manual? they help pretty good.
Old 07-13-2009, 06:13 AM
mdhimes's Avatar
Sooo... You want to move the ignition switch (the part the key goes into) from the column and mount it to the dash? It is uncommon to do this unless you are eliminating the steering wheel bezel as the absence of the ignition switch will leave an unsightly hole. Anyway, here are some tips.
First, rip it all apart. The biggest challenge is persuading the shear bolts away from the bracket. To do this drill a small dent into then and then tap them loose with a small screwdriver and hammer. Separate the ignition wires from the combination switches. Once the ignition is apart then you will likely need to make a snazzy bracket or something to mount it to behind the dash.
I did something sort of similar in my racecar. Because I had to build a custom steering column in order to fit my steering quickener I chose to eliminate the ignition switch. Essentially I rewired it to a main battery cutoff switch, an accessory switch, and a push-button start. Its pretty slick. The start button is in a sneaky spot in order to deter thieves.
Also, like the last guy posted. Get a manual if you are serious about this. PRICELESS!!!!
Old 07-13-2009, 06:21 AM
SpOoLiNg CiViC's Avatar
s2k push start where dimmer is and be done with it
Old 07-13-2009, 07:26 AM
huckaboo's Avatar
it doesnt say anything in the manual about moving the ignition switch to the dash. it only tells me how to change the oil. thanks though
and thank you mdhimes ill take a look at it but you described exactly what i need to do so hopefully it works thanks again
Old 07-13-2009, 08:13 AM
mdhimes's Avatar
We should have been more specific. Manual = Helms service manual. You can usually buy a CD rom off of ebay for like 10 bucks or maybe just find a download sight for free.
Good luck.
Old 07-13-2009, 12:52 PM
huckaboo's Avatar
and it will say how to do it?
low'n slow
09-06-2014 01:42 PM
kindness
08-31-2011 04:04 PM
jdmjosh1
03-31-2010 03:32 PM
99fbpem1
09-07-2007 08:36 AM
gspot
03-06-2003 09:18 AM
Quick Reply: how do you move the ignition from the column to the dash in a 1996 acura integra
