How do I test my gsr ignitor with a multimeter to check if it's good or bad? - Honda-Tech
Old 08-26-2004, 07:33 PM   #1
SaTownTegGsr's Avatar
Default How do I test my gsr ignitor with a multimeter to check if it's good or bad?
Can anyone please tell me how to test an ignitor with a multimeter to check if it's good or bad?
SaTownTegGsr is offline   Reply With Quote
Old 08-26-2004, 10:18 PM   #2
Default Re: How do I test my gsr ignitor with a multimeter to check if it's good or bad? (SaTownTegGsr)
Can anyone tell me?
Old 08-27-2004, 08:59 PM   #3
sugarloafpkwy's Avatar
a;right dude i hope you have a wiring diagram.
If you put one lead on battery positive and the othe ron the coil negative (-) screw and crank the engine (with the dist cover off) voltage shoul dbe like between 4 and 8 volts. this is cause the ignitor is rapidly swithcing the voltage from open and ground (12 volts and 0.1 volts averaged together). if not check the wire from the ECU to the ignitor for the same voltage so iit can tell the ignitor to fire.
sugarloafpkwy is offline   Reply With Quote
Old 08-28-2004, 07:57 AM   #4
Default Re: How do I test my gsr ignitor with a multimeter to check if it's good or bad? (sugarloafpkwy)
But is there a way I can test it with a multimeter?
Old 08-28-2004, 08:05 AM   #5
with the ignitor out of the distributor?
Old 08-28-2004, 11:41 AM   #6
not really. to check it it has to have power. You basically check to make sure that it's getting a signal from the ecu, and if it is it should ground and unground the coil. If you really wanted to bench test it, you'd have to kind of set up a whole mock ignition system
Old 08-28-2004, 11:46 AM   #7
The quickest check for ignitor is to take distributor cap off and put a test light on the coil (-) screw terminal, and put the other end on battery positive. Crank engine and if the light flashes and you're not getting spark then your coil is bad, if it doesn't flash it's 9 times out of 10 your ignitor. The only other things it could be would be TDC/CYL/CMP sensors inside the distributor, or the ecu, which are both pretty damn expensive.
Hope that helps.
Old 08-28-2004, 04:11 PM   #8
Okay thanks alot I appreciate it.
Learn me how to multimeter #ugonlearntoday $amGD3 General Discussion and Debate 41 02-25-2015 09:31 AM
checking if ignitor good or bad? SNsLude Honda Prelude 6 01-26-2006 08:08 PM
Multimeter tests...What settings? P@@RB@Y Honda Civic / Del Sol (1992 - 2000) 8 12-04-2005 11:21 AM
Coil, Ignitor Test? What readings to expect? Blaze45 Tech / Misc 3 07-01-2003 02:04 PM
how to check if an O2 sensor is good or bad with a multimeter? Loveless Acura Integra 7 06-14-2003 11:12 AM
Tags
bad, check, coil, distributor, distributors, distrubuter, furnace, gsr, honda, igniter, ignitor, multimeter, set, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
