How to adjust the timing belt? - Honda-Tech
Old 09-08-2006, 11:23 AM   #1
Default How to adjust the timing belt?
if u can post pics or explain on how to tighten the belt up, post them on here!
xafafax is offline   Reply With Quote
Old 09-08-2006, 11:50 AM   #2
DC2 Mang's Avatar
Default Re: How to adjust the timing belt? (xafafax)
loosen the tensioner, then turn the crank by hand a few teeth then re-tighten the tensioner
or you can to the coat hanger way
bend a coat hanger and loop it into the hole for the spring on the tensioner, and have a friend pull up on it as hard as he can while you turn the crank a few times, then tell him to hold it steady (because he will bitch that his fingers are hurting) and tighten the tensioner down
there should be no more than and inch of deflection total (or half and inch each way) on the intake and ehxaust side
DC2 Mang is offline   Reply With Quote
Old 09-08-2006, 12:22 PM   #3
Default Re: How to adjust the timing belt? (DC2 Mang)
lol my bad i had a friend post this for me but i did forget to mention that it is a B18A1
Old 09-08-2006, 12:48 PM   #4
I drive a G35, it's silver, surprised?
CARMA_626's Avatar
Quote:
Oh a B18A1? Well that's totally different. In that case you should do this:
CARMA_626 is offline   Reply With Quote
Old 09-08-2006, 12:54 PM   #5
Default Re: How to adjust the timing belt? (CARMA_in_da_626)
dick, hey for all you guys new it koulda been a k-series
Old 09-08-2006, 12:59 PM   #6
lVlemphizStylez's Avatar
yea except the k series doesnt use a timing belt...
lVlemphizStylez is offline   Reply With Quote
Old 09-08-2006, 05:58 PM   #7
CARMA_626's Avatar
Default Re: How to adjust the timing belt? (lVlemphizStylez)
Quote:
xafafax, You got suuurved!
Old 09-09-2006, 02:24 AM   #8
Quote:
just goes to show ya i know nothing about k motors lol B series rule FTW!!!!
How to tell if the timing belt is bad? dudesitsjdm Acura Integra 14 09-22-2010 12:11 PM
how to change fan belt tensioner that is located at fan belt. how to loose the fan belt thunderboy Honda Civic (2006 - 2015) 3 06-07-2008 07:51 PM
type r stock timing belt? realis9 Acura Integra Type-R 2 07-19-2005 08:47 AM
does anyone have a h22 lower timing belt gear for sale? how do u post a pic dimes_prelude Honda Prelude 1 05-28-2005 09:30 PM
Timing belt on Z6 ^Sammy]!. Tech / Misc 1 08-07-2004 11:19 PM
Tags
adjust, b18a1, belt, coat, hanger, hard, series, tighen, tighten, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
