how about this car??
New User
Well the 94 integ that I was hoping for and posted last time about was a bust...I will remember to stay away from salvage title stuff....I looked at it and could tell the frame was bent(hood didnt fit right, tail lights had gaps between the body, and uneven wear on the tires)...anywho what do you guys think about a '93 LS with a '97 h22 engine in it? heres a link to a small pic http://jc2k2.homestead.com/files/706...46_240x180.jpg
[Modified by jc2k2, 1:02 AM 8/3/2001]
Re: how about this car?? (jc2k2)
well if your into handeling..... its gonna suck. that motor is really heavy and the car is gonna handle like poo. but if you just want speed for say the 1320 then it wouldnt be bad. you can make that a really fast drag car. how much is it goin for?
Re: how about this car?? (integls98)
the H22a only weighs 70lbs more than the b18c....if he took the battery and moved it to the rear, removed some other stuff (cruise control...blah blah blah) and got some performance headers which are more lightweight...it would be ok...just make sure to get good spring rates and swaybars to make it handle correctly, it will dig more in corners...but its not anywhere near as bad as some people make it to be...
New User
Im not sure...I only have about 5.5k to spend...I think I just will wait and save a lil more till I can find a '94+ integra...I like the g3 body style better anyway....
If you want something quick in the 1/4 mile though, that G2 is hard to pass on if everything is in good working order. A 91 G2 LS will normally run around $2.5K and the swap alone will be well over $3.5K so I'd think you were getting a good deal, but of course since it is swapped, you'd have to make sure that the engine hasn't been beaten to hell since in all likely hood since it was built to go fast, it probably has gone fast.
SlowSOHC-T
10
03-23-2006 01:01 PM
