HID experts, please help.
this is a dual beam h4 hid bulb, notice the 3rd wire coming from the bulb
I currently have a single beam set up but one of my bulb was damaged. I was wondering if I can install a dual beam bulb on a single beam ballast/ignitor and the low beam would still work? The connects looks like it will fit leaving the 3rd wire hanging which is used for triggering high beam, I tjhink
Re: HID experts, please help. (Loveless)
What application is this? Integras don't use H4 that I know of.
Civics use H4, but the problem is that the low beam turns off when you switch to high beam. You would need to do some custom wiring that would allow that low beams (and thus the ballast) to stay activated while you switch to high beam (which in this case would only be activating the solenoid that moves the bulbs fore/aft).
itsmejto
06-22-2008 04:11 AM
