Help - Timing Belt Tensioner Bolt Stripped
Alright, I'm really close to gettin my motor up and running until, the timing belt tensioner bolt would not come up, resulting in almost stripping it, what should I do to get it out? Im considering some honda-bond, and then honda-bond the socket to whats left of the bolt, any ideas or anything to help,
Im trying to get the old one out, and the new one in,
thanks guys
mods move to the right forum if you feel needed, thanks
thanks guys
Re: Help - Timing Belt Tensioner Bolt Stripped (jtintegra)
The twist sockets from snapon are the best thing ever http://buy1.snapon.com/catalog...talog I think sears makes a similar product. They pull themselves onto the bolt as you try to loosen it. I had a stripped tensioner on my integra and had been struggling with it for hours. One of these took it out instantly.
-Jeremy
-Jeremy
Re: Help - Timing Belt Tensioner Bolt Stripped (jag)
drill the head and then get some screw outs. attach the screw outs to a drill and youre dont. acura sells new tensioner bolts for like $5
Re: Help - Timing Belt Tensioner Bolt Stripped (King_j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King_j »</TD></TR><TR><TD CLASS="quote">drill the head and then get some screw outs. attach the screw outs to a drill and youre dont. acura sells new tensioner bolts for like $5</TD></TR></TABLE>
I doubt that will work unless the motor is out of the car, as the frame rail is probably in the way.
Re: Help - Timing Belt Tensioner Bolt Stripped (PatrickGSR94)
ok im about to go out to the shop to continue work on it, anyone have any more ideas, last i heard was beat, or jar up the bolt to loosen it up then try to get the bolt free that way
Re: Help - Timing Belt Tensioner Bolt Stripped (Sleeper)
Mine was stripped out to **** before as well as frozen. So I took it to a shop and well they welded
a nut on top of the stripped tensioner bolt and wham... came right off....
1 Post
Re: Help - Timing Belt Tensioner Bolt Stripped (BuddyClubDC2)
ok we finally got the bitch out.. ended up having to WELD a socked on the bitch and then turning it... man that motherbitch set us back when we were on a roll.. you gotta get a picture of that bolt john!
White91EF
11-01-2022 07:26 PM
cobaltss
08-21-2012 07:06 AM
