help with low idle during startups
ive been having a low idling problem where it would start to shutter occasionly nothing i thought much of until today. i tried starting up the car and it didnt even want to startup, it just shuttered and died. so i gave it gas while starting up and it helped with the start. i recently changed the fuel filter if that matters which i doubt. someone help me out.
Re: help with low idle during startups (G1_TEGGY)
car has 30k on it and its a 2000? new head gasket? you sure about that? the car is pretty stock also
Re: help with low idle during startups (00b18b)
doesn't matter how many miles there are, a gasket can go bad at pretty much anytime.. plus if it wasn't the gasket then it's either a snapped head bolt or a crack in the block, so which would you rather more likely have happen?
Frost_1097
06-18-2007 07:21 PM
westspeed
07-12-2005 10:27 PM
