Help!!!! Brake piston won't go back in!!! - Honda-Tech
Old 03-15-2004, 07:36 PM   #1
hodsintegra23's Avatar
Default Help!!!! Brake piston won't go back in!!!
I can't get the front brake piston to go back in at all.
I opened the Master cylinder and pushed on it but that didn't work and i tried to turn the valve but it wouldn't move. I toke the rubber cap off and that didn't work.
What do I need to do to get the piston to go back in?
hodsintegra23 is offline   Reply With Quote
Old 03-15-2004, 07:44 PM   #2
morepoop4u's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (hodsintegra23)
what did you use to push the piston back in? did you use a c clamp?
morepoop4u is offline   Reply With Quote
Old 03-15-2004, 07:49 PM   #3
Default Re: Help!!!! Brake piston won't go back in!!! (morepoop4u)
no i was just using some pliers.
Old 03-15-2004, 07:50 PM   #4
blackdude's Avatar
you have to use a brake piston compressor
blackdude is offline   Reply With Quote
Old 03-15-2004, 08:01 PM   #5
JakT's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (blackdude)
Just go buy a cheap *** c clamp, then put the old brake pad on the piston flat. And screw down the clamp on the brake pad and the caliper backside, this will push the piston back in with out any damage.
u dont need any special gay *** tools
JakT is offline   Reply With Quote
Old 03-15-2004, 08:05 PM   #6
Riceburner247's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (JakT)
Quote:
That's how I've always done my brakes. Should work fine.
Riceburner247 is offline   Reply With Quote
Old 03-15-2004, 08:22 PM   #7
Train's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (riceburner247)
i haven't changed my front pads yet, but i did my rears, and the piston doesn't "push" in, it "turns" in. i took a pair of needle nose pliers and opened them up in the groove of the piston, and turned (clockwise, i think. that would make sense), and it went in. i tried using a c clamp and it didn't work. i would assume the fronts are the same way.
Train is offline   Reply With Quote
Old 03-15-2004, 08:42 PM   #8
tC_Dragon's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (Train)
Quote:
U are right about doing the rears, that way, but totally wrong for the fronts... teh front does not have any cross in the piston and does not screw in like the rears do. The fronts just need to be compressed in... i did my pads last week and i always use simple c clamps to recompress the piston, but not on top of the pads. I compress without the pad, then put the pad on... so i won't damage the surface of the pad.
tC_Dragon is offline   Reply With Quote
Old 03-15-2004, 08:46 PM   #9
Moderator in Chief
Muckman's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (pdcdragon)
Brake Pad Spreader
Big *** C clamp also works. Could also bleed the piston too
Muckman is offline   Reply With Quote
Old 03-15-2004, 08:50 PM   #10
dannylDAsport's Avatar
thats how i did my front brake, works fine
dannylDAsport is offline   Reply With Quote
Old 03-16-2004, 06:22 AM   #11
JimBlake's Avatar
Quote:
If you wedged the piston crooked, you may have already damaged the cylinder wall. If so, you need a new caliper... The C-clamp or piston compressor pushes into the bottom of the hollow piston so it goes in straight.
JimBlake is offline   Reply With Quote
Old 03-16-2004, 06:58 AM   #12
Solracer's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (JimBlake)
Just open the brake bleeder screw, you can then practially push it in by hand.
Solracer is offline   Reply With Quote
Old 03-16-2004, 07:55 AM   #13
shardul's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (Solracer)
u can rent a brake piston compressor at your local autozone for a few bucks ....
shardul is offline   Reply With Quote
Old 03-16-2004, 09:42 AM   #14
SecretAznMan4u's Avatar
a c clamp, or just start the engine up, it will release the pressure in the cals. are you sure your cal. isnt locked up?
SecretAznMan4u is offline   Reply With Quote
Old 03-16-2004, 12:21 PM   #15
ThePro's Avatar
Quote:
on this!
I bought one from Harbor Freight Tools for 3.75 and it works like a champ.
ThePro is offline   Reply With Quote
Old 03-16-2004, 12:49 PM   #16
dip-set's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (ThePro)
u do have the brake fluid resevoir open dont you? meaning the cap is off?
dip-set is offline   Reply With Quote
E-brake question....help please ss73 Suspension & Brakes 5 04-28-2016 04:39 PM
Help......brake job gone wrong. ss73 Tech / Misc 6 04-13-2016 02:42 PM
Bleeding brakes on an '03 Pilot? Splat Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 1 12-17-2007 01:38 PM
2000 accord rear brakes Stu's Car Honda Accord (1990 - 2002) 4 07-31-2006 04:18 AM
brake pad replacement, can't push piston back sportbike954 Honda Civic / Del Sol (1992 - 2000) 9 04-01-2005 10:40 PM
Tags
2004, 97, acura, back, brake, clamp, integra, maxima, pad, piston, pistonwont, push, spreader, tl, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
