Head Gasket. Is OEM Best? AND: Torque Specs? (ARP) - Honda-Tech
Old 01-14-2010, 09:22 PM   #1
Default Head Gasket. Is OEM Best? AND: Torque Specs? (ARP)
its going on a GS-R block and will be squished down with ARP head studs through a B16 head.
so OEM or aftermarket or whadda?
and, does anybody have the torque sequence i should use with ARP head studs? do you do them all at 25, then go back and do them all at 45, then go back and do them all at 80? (that is just an example, not actual numbers)
was told ARP head studs should be tourqued to 80ft-lbs. correct/incorrect?
88CRXJ is offline   Reply With Quote
Old 01-14-2010, 09:26 PM   #2
p28yaj's Avatar
Default Re: Head Gasket. Is OEM Best? AND: Torque Specs? (ARP)
Search ^^ or can be googled!
p28yaj is offline   Reply With Quote
Old 01-14-2010, 09:54 PM   #3
ACTUALLY. when you search "best head gasket" it comes up with a billion finds... that i really dont feel like searching through for a simple answer. its because everybody puts what kind of bad *** head gasket they have when they describe their vehicle. i too one day would like to be able to do this, as soon as i find out with head gasket is the most bad ***. haha. any opinions?
Old 01-14-2010, 09:57 PM   #4
KPPPowa's Avatar
Quote:
Typical HT response.
your welcome.
http://www.honda-tech.com/showthread.php?t=2279128
KPPPowa is offline   Reply With Quote
Old 01-14-2010, 10:10 PM   #5
Quote:
your welcome.
seriously. i hate it when people see the oppurtunity for a "use the search button" and abuse it to sound cool. i know SOMEBODY out there knows where the thread is. thanks for helping.
can you suggest a headgasket? been told OEM is best...
thanks again!
Old 01-14-2010, 11:41 PM   #6
mouab18c1's Avatar
OEM is best for a stock or semi builds. If you're ordering a new set of ARP headstuds, it should come with torque specs.
mouab18c1 is offline   Reply With Quote
Old 01-14-2010, 11:42 PM   #7
Spawne32's Avatar
fel pro gaskets are perfectly fine, call ARP for the proper torque sequence and specs though, not the same as factory at all
Spawne32 is offline   Reply With Quote
Old 01-14-2010, 11:57 PM   #8
mouab18c1's Avatar
Quote:
i torque mine in OEM sequence and using the lube ARP provides i torque them to 68lbs and have never had any come loose. I've double checked after a few months of driving and beating on it and they're still tight like they should be.
Old 01-15-2010, 12:00 AM   #9
SoTexDC2's Avatar
When it comes to torquing any mating surface separated by a gasket, I like to take as many steps as possible. Use the Helms manual for the proper sequence. Better safe than sorry.
SoTexDC2 is offline   Reply With Quote
Old 01-15-2010, 12:17 AM   #10
Quote:
ARP studs are already in there but i dont remember or have the papers.
Quote:
Helms manual. ill hjave to look that up. thanks.
no turbo is going on this. just all motor poormans type r. may end up getting cams idk. so OEM is sounding fine.
Old 01-15-2010, 10:26 AM   #11
mouab18c1's Avatar
yes OEM will be fine for your poorman's type r build
Installing arp head studs without removing head question TravisBiggie Acura Integra 16 05-18-2012 03:31 AM
ARP Head studs B18C Torque procedures. Romo Pyro Tech / Misc 10 03-09-2010 02:46 PM
Arp head studs 95_red_dc Acura Integra 4 08-31-2008 10:28 AM
ARP Studs VS OEM head bolt xasiansupermanx Honda Civic / Del Sol (1992 - 2000) 3 11-11-2007 08:37 AM
Running all but 1 arp head stud? Im missing one! Turbo EH2 All Motor / Naturally Aspirated 24 12-20-2006 02:20 PM
Tags
1989, acord, arp, b16, b16a, gasket, head, honda, integra, pattern, sequence, spec, stud, tork, torqhe, torque, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
