Have 1994 Acura Integra - brakes keep failing for no reason! - Honda-Tech
Old 07-09-2004, 10:23 AM   #1
sykowmn36's Avatar
Default Have 1994 Acura Integra - brakes keep failing for no reason!
My mother has a 1994 Acura Integra. She has had constant brake problems. The ABS light stays on all the time. She takes to the mechanic who says there is nothing wrong. But when she comes to a sudden stop the brake pedal will sometimes go all the way to the floor for no reason. She pumps the pedal and it will return to normal position. She's had new brake pads ,etc... They squeak all the time.
She is at the end of her rope. Any ideas??
sykowmn36 is offline   Reply With Quote
Old 07-09-2004, 10:32 AM   #2
Slo Car's Avatar
Default Re: Have 1994 Acura Integra - brakes keep failing for no reason! (sykowmn36)
if she is loosing pressure i.e. the pedal goes to the floor...then it's probably the master cylinder has gone bad...
Slo Car is offline   Reply With Quote
Old 07-09-2004, 11:08 AM   #3
Kendall's Avatar
Quote:
Sounds like you need to find a new mechanic.
Check the brake booster and associated hose for leaks and then take the master cylinder and have it checked out.
Kendall is offline   Reply With Quote
Old 07-09-2004, 11:44 AM   #4
iH8RICERZ's Avatar
Default Re: Have 1994 Acura Integra - brakes keep failing for no reason! (Kendall)
my 94 gsr has the same exact problems.......my abs light stays on, abs doesnt work, checked the code and my car says its my passenger front wheels speed sensor............then once in a while (not all the time), my brake pedal will go to the floor............i havent replaced the master cylinder in years, so thats probably my problem
iH8RICERZ is offline   Reply With Quote
Old 07-09-2004, 02:20 PM   #5
94civicEX's Avatar
Just like they said, get a new mechanic and a new master cylinder.
94civicEX is offline   Reply With Quote
Old 07-10-2004, 12:55 AM   #6
ctegsta's Avatar
same problem with my 94 , its the master cylinder
ctegsta is offline   Reply With Quote
Old 07-10-2004, 06:21 AM   #7
Cliffjumper2's Avatar
agreed
Cliffjumper2 is offline   Reply With Quote
97 TEG Sedan - Happy 20th 97teg4drdd Appearance Build Threads 12 10-28-2016 12:43 PM
Story of my R (01-0460): We were meant to be porofek Acura Integra Type-R 3 08-29-2016 12:53 AM
G/f trouble Chingy24 General Discussion and Debate 78 05-09-2006 04:35 PM
What the heck is wrong with my cat? brian estrada General Discussion and Debate 90 10-29-2005 09:41 PM
problem with the brakes... LAKER HATER Acura Integra 6 10-22-2005 02:33 PM
Tags
1994, 199401, 94, acura, booster, brake, brakes, breaks, failing, floor, integra, pedal, pressure, why, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
