H-motors online
Old 09-22-2010, 07:26 AM
slowdc123's Avatar
Default H-motors online
So ive noticed alot of people it seems here on hondatech purchase their swaps from H-motors online? Theyre a credible shop? They also advertise all their swaps are around 35k miles? Thats really low...u guys think that is accurate? What are some experiences?
Old 09-22-2010, 07:32 AM
EMTof DEATH's Avatar
Default Re: H-motors online
I got my b16a from them. It went in without a problem. the only thing i would suggest is that you wake sure that the timing is set right mine was off a little bit. But i have had my engine for about a year now and have put on about 8000 miles on it without any sirous problems. You know the usual **** that happens when u beat the engine.
Old 09-22-2010, 07:35 AM
Jidum_DC's Avatar
Ive bought a gsr an an h22 from these guys an various little nic nacs never had a problem out of any of it i will continue to shop from these guys...
Old 09-22-2010, 07:43 AM
slowdc123's Avatar
Thanks for input guys, im thinking about going with a GSR swap and just shopping around
Old 09-22-2010, 07:45 AM
komat's Avatar
hmotors the best. steve has great customer services... i had a bad clutch on one of my b16 swap. without asking me , he just send me best used oem gsr clutch he had in stock for free.
also they clean there motors, compression and leakdown test there motors
Old 09-23-2010, 05:14 AM
slowdc123's Avatar
If i have a ls aftermarket catback exhaust, and i drop in a 94-99 gsr what will i have to do to make it work? I know that exhausts are interchangeable with 94-01 ls/gs/rs and 00-01 gsr's, but is the 94-99 gsr shorter than my 2000 LS or longer?
Old 09-23-2010, 05:40 AM
I requested a short story for a title.
stocker2shocker91's Avatar
no need to continue, you have already found the best place
Old 09-23-2010, 06:42 AM
Alvi84's Avatar
I bought my 96 JDM SiR-G (B18C aka JDM Gs-R) from HMotors earlier this year and the motor is strong as hell. My motor came with documentation stating it had 47,000 miles on it so the 35k is an average. My motor hasn't lost a drop of oil since i put it in 4 thousand miles ago (Royal Purple synthetic so I don't have to change until 5k miles just so I don't get any comments about needing and oil change) and I get 29MPG with mixed driving. Customer services was also great and the shipping company was flexible as well. I wouldn't even think to buy from anywhere else.
The only problem whatsoever was the MAP sensor that came with the motor was bad and when I started the car it was literally spitting gas out the exhaust until I swapped MAP sensors. Once I put the MAP sensor from my old B18C1 the car was off and rolling.
Old 09-23-2010, 07:50 AM
slowdc123's Avatar
What about this guys? i dont want to run into a huge headache down the road...
Old 09-23-2010, 09:12 AM
tweek_boii's Avatar
do some research, you already got your fist question answered.
Old 09-23-2010, 09:32 AM
evildc2's Avatar
Shorter
Old 09-23-2010, 12:45 PM
racebum's Avatar
you guys better be changing the timing belts on these motors when you get them. even a 2001 motor is right at the 10 year mark which regardless of mileage is time for a change.
as for hmotors, his gsr deals are inline, deals on random parts are good and itr swaps are on the higher end of what the market will support. the ctr/itr stuff is the only place i think he's overpriced.
Old 09-23-2010, 01:08 PM
b16racereg6's Avatar
i bought a b16a from their about 4 years ago. And motor was strong as ****. CLEAN AS HELL TO. I changed timeing belt water pump and oil pan gasket and value cover gasket to because it was out. Along with clutch. Now this year i checked compresion about 30,000 miles later It was mint all the way accross the board and i boosted it and it runs like a champ. WILL ONLY GET MY MOTORS FROM HMO!!!!!!! A++++ PPL THEIR
Old 09-23-2010, 01:31 PM
EL Vap133's Avatar
Very good service, quality products!
Old 09-23-2010, 03:24 PM
'00_GSR/R's Avatar
I got my 98 B18c-R from them. It still runs like a bat out of hell, and Ive put about 25,xxx miles on it since the purchase. Nothing has gone wrong with the engine at all. Did the Tbelt and waterpump, and checked valves when I got it. Head still looks brand new inside. The only problem is it ate both my GSR axles and the motor mounts. LOL.
The full swap was like $6k (good price back then) with a ton of extra ****. 36mm axles, ITR linkage, one Recaro seat, couple ecu's, and some other nick nacks. Went down there and saw my donar ITR in person before getting it to make sure I got my money's worth. I won't go anywhere else....
brandond
06-01-2004 09:05 AM
stripes777
12-19-2003 09:20 PM
dav3ddt
08-22-2003 02:26 PM
Mark
11
01-15-2003 08:03 PM
Quick Reply: H-motors online
