GSR vs TYPE R brake master cylinder
Old 06-30-2005, 09:28 PM
omiehomie's Avatar
Default GSR vs TYPE R brake master cylinder
i have been looking on itrsport.com and searching through the ht archives and i have not had much luck. my question for you guys is, is the brake master cylinder for a gsr the same as the brake master cylinder as the type r?
because i have run into a brake master cylinder for a gsr, and i was wondering if it would work for a type r?
Old 06-30-2005, 11:33 PM
mingbling96's Avatar
Default Re: GSR vs TYPE R brake master cylinder (omiehomie)
yes.. both 1"
Old 07-01-2005, 12:00 AM
iH8RICERZ's Avatar
i was told that the itr and gsr one was different. I was going to buy an itr one from ebay, I asked the seller if it would fit a GSR correctly and he replied with "NO, the GSR & ITR master brake cylinders are different"..he also said some other stuff but i forgot. Not sure if what he said is a 100% accurate, but eh
Old 07-01-2005, 02:22 AM
campbuds's Avatar
part f a true 5 lug conversion is the brake booster and brake master cylinder.
Old 07-01-2005, 07:35 AM
UberMunkey's Avatar
parts catalog lists the same part numbers for all 98+ ABS equiped integras, including ITR.
m/c - 46100-ST7-L52
booster - 46400-S84-E01
Old 07-01-2005, 08:36 AM
SMZ GSR's Avatar
Default Re: (UberMunkey)
Not all GSR's had 1" MC.
My 98 did though
Old 12-03-2007, 07:10 AM
Jdmls's Avatar
Default Re: (SMZ GSR)
What about the ls brake master cylinder?Going to upgrade my brakes really soon
Old 12-03-2007, 07:11 AM
Jdmls's Avatar
Default Re: (Jdmls)
Is it the same size or smaller?
Old 02-15-2008, 03:34 PM
graveltravel2's Avatar
lt is 15/16
Modified by graveltravel2 at 6:20 PM 2/16/2008
Old 02-15-2008, 04:40 PM
IN VTEC's Avatar
It depends on if you're crossing the design change between certain years (i.e. '98+ or whatever year they changed it).
The older GS-R master cylinders and boosters used a diagonally placed bolt pattern and different sized flare nut threads on one of the ports.
The newer brake master cylinders and boosters are compatible no matter if it's an ITR or GS-R.
Old 02-15-2008, 04:43 PM
Daisy... Daisy...
Dogginator's Avatar
94-97 GSR is different that the USDM ITR. 98-01 GSR is the same as the USDM ITR. They are all 1".
hunan beef
05-09-2011 03:43 PM
omiehomie
07-02-2005 05:09 AM
BoOsTiN Dc2
02-25-2005 06:47 AM
jr_istheman
06-24-2003 11:05 AM
jr_istheman
06-23-2003 05:17 AM
Quick Reply: GSR vs TYPE R brake master cylinder
