GSR has bad engine mount, rear or transmission mount? - Honda-Tech
Old 07-28-2009, 05:50 PM   #1
gs_rbaby's Avatar
Default GSR has bad engine mount, rear or transmission mount?
Is there a difference from the rear mount to the transmission mount? I need to take care of this asap! It vibrates and makes a noise that you can hear from inside the cabin. Noise is apparent from 3-4,300 RPM only and dissapears beyond 4,300 and below 3,000 RPM. It sounds like the header or piping but, I checked all bolts and brackets to ensure that everything is tight. There was a loose bracket and I thought it was the problem but, still wasn't it. Can anyone suggest any ideas? Oh, I can feel the vibration from my pedals and a bit from the shifter as well. It's just annoying, so please help fellas, thx in advance.
gs_rbaby is offline   Reply With Quote
Old 07-28-2009, 08:48 PM   #2
gs_rbaby's Avatar
Default Re: GSR vibration noise from engine.....
Bump.
Old 07-28-2009, 09:19 PM   #3
Genetically Gay
KILLAB17VTEC's Avatar
does it happen at startup idle?engine suppose to have vibration..if it shakes bad then thats different..your rpm seems pretty high.it can be bad motor mounts.
KILLAB17VTEC is offline   Reply With Quote
Old 07-28-2009, 09:33 PM   #4
gs_rbaby's Avatar
Quote:
it does it wether it's cold or warm. Although, the vibration is more present when the ac is on. When it idles and I rev it up to 3-4,300 RPMs, it vibrates. In addition, if I hold it there, it gets annoying loud. During freeway drives, it's also apparent there as well. I'm guessing a loose bolt or another bracket rubbing against eachother to cause the vibration.....I'm just frustrated and I hope I get the irritating noise to dissappear.
Old 07-28-2009, 11:28 PM   #5
95DC2GS-R's Avatar
What kind of mounts do you have?
What kind of header and exhaust?
Do you still have the heat shields under the car?
I had multiple rattling sounds from my GSR and it was the exhaust hitting the heat shields, and then the actual pipe in the header collector rattling around. This accured after two-stepping going open header.
95DC2GS-R is offline   Reply With Quote
Old 07-28-2009, 11:42 PM   #6
DEEABLO's Avatar
Looks like we're having the same problem...
http://www.honda-tech.com/showthread.php?t=2616934
DEEABLO is offline   Reply With Quote
Old 07-29-2009, 09:47 AM   #7
gs_rbaby's Avatar
The car is completely stock. So yes, it still has the heat shields on. I'll try checking that and see if it's the heatshield creating the vibration noise.
Old 07-29-2009, 12:18 PM   #8
gs_rbaby's Avatar
And the engine sits still with no movements at all when I rev the engine from the throttle cable. So I'm sure it may not be the mounts.
Old 07-29-2009, 10:55 PM   #9
95DC2GS-R's Avatar
Quote:
It won't really move in nuetral.. When the car is in gear, and you accelerate the engine thrusts back.
Old 07-30-2009, 02:15 PM   #10
gs_rbaby's Avatar
Hmmm, maybe the mounts in the rear of the engine itself?I do notice that when I backup, the engine seems to make a noise or clunk sound everytime I let off the clutch.
Old 07-30-2009, 02:31 PM   #11
gs_rbaby's Avatar
Yeah, it is the engine mount. I drove it back and forth in my drive way with the hood open and noticed the engine rocking back and forth when I'm in gear. How hard is it to replace this on a scale 1-10?
Old 08-02-2009, 04:58 PM   #12
gs_rbaby's Avatar
Default Re: GSR has bad engine mount, rear or transmission mount?
Bump guys, I need some advice.
N22A2 i-CTDI turbo diesel into EG gerryturbo Hybrid / Engine Swaps 23 03-14-2016 11:44 AM
94-01 integra bseries mounts/ 92-95 civic bseries ProjectBoosted Northwest (Sales) 1 11-12-2008 10:02 PM
Extremely loud vibration at 4k rpms + with rear Hasport mount 1SlowSi Tech / Misc 7 11-01-2008 06:42 AM
h22a ej and vibration problem. GeeGee Hybrid / Engine Swaps 6 12-07-2005 11:25 PM
Type S: Just finished ES motor mount install... sjracer Acura RSX DC5 & Honda Civic EP3 5 03-07-2003 12:05 PM
Tags
95, bad, civic, diff, gsr, integra, loose, motor, mount, noise, rear, tranny, transmission, type, vibraters, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
