Ground strap is fine for valve cover ground?
I'm looking to ground my valve cover to the frame. But don't have any extra grouns laying around would a "ground strap" from autozone work as well?
1 Post
Re: Ground strap is fine for valve cover ground?
Yes it comes factory installed. Doesn't have to be on the front but you should have one from the VC to the chassis.
theres multiple engine ground points, but its good to keep all the factory locations in place, they are all merely wires of various sorts connecting two points of contact, you just have to make sure the wire is a sufficient size. Usually 14g or better on that valve cover ground.
get a foot or so of some 10g wire and crimp some connectors on the end and call it a day. heat shrink over the plastic pieces of the connectors if you want it to have that clean look
civicgsr499
06-05-2009 11:41 AM
Razr2
10-15-2008 06:31 AM
GeorgeJetson
10
01-16-2004 09:54 AM
