Gator Grips work on these...?
Old 03-11-2009, 06:48 PM
A-dub5513's Avatar
Default Gator Grips work on these...?
Yeah, lost the key for the first time in 10 yrs. So you guys think a Gator socket will fit? My goal is to get one off with the splines intact, so that I can send it to the manufacturer for a replacement key.
Old 03-11-2009, 06:49 PM
roadsqueegy95's Avatar
Default Re: Gator Grips work on these...?
ya i think it would, worth a try i guess
Old 03-11-2009, 10:20 PM
XxNampsterxX's Avatar
I've tried gator grips with locks and it doesn't work. Gator grips just aren't strong enough to take them off. When I lost my key, I had luck with two different methods. I was able to find a socket that was a little smaller than the lug and hammer it on. After the first one came off, the socket wasn't any good anymore. Another thing that I did was get a key from the same brand and hammered that on. I was able to get the rest of them off with the key. I hope one of these ways work. Good luck!
Old 03-11-2009, 11:41 PM
A-dub5513's Avatar
I don't think it's so much that the Gators aren't strong enough, just that those spring-loaded 'whatchamacallits' in the sockets look kinda big. I'm thinkin' if the various shapes of the splines on the lug locks are just big enough, but only by a hair, to push those "rods" back, you may have too much play, resulting in a weak grip. You know what I'm tryin' to say?
As for the second method, woudn't work as I need the splines intact to send to the manufacturer.
Another promising method is the universal stripped bolt/nut removal kit, the socket kit with the reversed threads. I wonder if they make one small enough to just thread into only the top half of the lug lock (cone-shaped half).
I will continue to ponder...and maybe take my a** to Sears! Hey, thanks for the suggestions guys.
A-dub
douft22
04-03-2010 08:20 PM
Xyphon
02-09-2009 10:58 PM
gooberguy31
04-18-2008 04:42 AM
k4ff1n3
05-20-2005 06:58 AM
typer.org
10-26-2002 06:47 AM
Quick Reply: Gator Grips work on these...?
