Which gaskets to change with new cams install?
Old 06-28-2004, 07:36 PM
G2Fanatic's Avatar
Default Which gaskets to change with new cams install?
I'm gonna be installing new cams soon. Was just wondering what gaskets/seals I should change while I'm in there. Here is what I've come up with so far:
Valve cover gasket
Sparkplug seals
Gaskets under the valve cover bolts
Distributor O-ring
Cam seal*
*Is there one cam seal per cam? If so, are they the same part no.?
Anything else I should replace?
Thanks.
Old 06-28-2004, 07:40 PM
Sack Master's Avatar
Default Re: Which gaskets to change with new cams install? (G2Fanatic)
Someone will chime in with the proper names but you should replace the cam seal(distributor side) and the 2 cam seals on the timing belt side. I would say with the 0-ring, gromets, valve cover gaset and spark plug seals, you just about covered it. If your timing belt is old I would replace that as well.
Old 06-28-2004, 07:47 PM
PLAGUED_DB7's Avatar
Default Re: Which gaskets to change with new cams install? (Sack Master)
I thinks Mr. Gasket gots a package for the b18 motors that supply you will all the gaskets you need....
Old 07-07-2004, 03:04 PM
B00ST2nR's Avatar
Default Re: Which gaskets to change with new cams install? (theplague83)
I used the same gaskets for my Cam Swap 4 times with NO problems. No leak.
Old 07-07-2004, 03:19 PM
TurboB18C1's Avatar
if there vtec cams that you are replacing dont forget the ORFICE!
I would inspect all the seals and if there is any wear i would replace them but the only item i ever changed was my valve cover gasket..
What kind of cams did you get if you dont mind me asking>> ?
1990IntegraLS
05-22-2016 02:59 PM
CNSK
10-27-2005 01:17 PM
blackdude
03-17-2004 08:55 AM
EleanoR
01-11-2003 10:32 AM
four27
01-25-2002 02:54 PM
Quick Reply: Which gaskets to change with new cams install?
