Vtec issue
Vtec issue
i have a 95 Gs-r, we bought a hondata s300 socketed to a p75, plugged that in with the base map. The vtec on switchin over on the computer but the CEL is on throwing a code for "Vtec spool" and the Vtec doesnt engages. At the meanwhile we throw the factory p72 ecu back in the Vtec engages but my tuner told me I have no Vtec...but it does crossover. Could it be the Solenoid?
Re: Vtec issue
the p75 s300 uploads and reads everything in the car...can u elaborate what you mean by something's wrong with it? 2nd I was gonna try doin a jump harness...or just buy a solenoid which is $175 at the dealer..
Re: Vtec issue
it's not the solenoid cause you said when you put back the stock ecu everything works fine...you have to check the socket on the ecu and make sure that it has signal...even tho the ecu says it works doesn't mean it really is working...and most of the time if you get the check engine light for that code...it's disconnect...
Re: Vtec issue
