Fuel injectors - how to clean
Old 11-26-2001, 05:39 PM
New User
michaelpr's Avatar
Default Fuel injectors - how to clean
How do you know when your fuel injectors need cleaning?
Is it best to put cleaner in the gas tank or to remove the injectors and clean them?
Is it difficult to remove each injector to clean?
Old 11-26-2001, 06:52 PM
gsr camel's Avatar
Default Re: Fuel injectors - how to clean (michaelpr)
Run the car til on empty then put in 2 gallons and put 2 things of NOS racing octain booster and I promise they will be cleaner but I dunno the effects of this on the engine I also dont know if this will harm any thing and I have not tested it I am just a post ***** hehe nah but just throw some injector cleaner in your gas tank.
Old 11-26-2001, 07:04 PM
Gee3's Avatar
Location: Formerly of SF moved to DFW and now back in SF, CA, USA
Go to the store and buy the Chevron Techron fuel cleaner. Not the ProGard stuff but the actual "Techron" cleaner. A friend at Honda says the Honda Engineers swear by the stuff. I use it a couple times a year even though the bottle says to use it every 3000 miles or something.
Old 11-27-2001, 05:42 PM
New User
michaelpr's Avatar
How does using a cleaner in the gas compare to taking each injector out to clean it by hand?
What are the negatives in using cleaners in the gas??
Old 11-27-2001, 06:07 PM
Gee3's Avatar
Cleaning it out by hand is probably a good idea every once in a while. The only problem is that you can't get inside the injector itself to clean the internal parts. That's where the fuel injector cleaner in the tank deal comes in. Or sending them to RC engineering to have them cleaned professionally.
There aren't any really bad sides to an in-tank cleaner. Just follow the directions on the bottle. Most will have you put it in at a near empty tank and have you drive around a bit before your next fill up. That way you get more of a concentration of the cleaner flowing through the injectors. Good luck!
Old 11-27-2001, 07:52 PM
ingrate's Avatar
Default Re: Fuel injectors - how to clean (Gee3)
snap-on has this neat little contraption.. it screws on after the fuel filter.. you disconnect your fuel pump and then fill in the container with half chevron's techron and the other half chem-tool injector cleaner. then just start it up and the car will run off of the cleaning solution.. just let it idle 'til it runs out. not only does it give your injectors a nice thorough cleaning but it also cleans the intake valves and the combustion chamber. you can find it on snap-on's webpage somewhere.. if it's too much cash maybe you could find a shop that'll do it for you
Old 11-29-2001, 06:06 PM
New User
michaelpr's Avatar
Default Re: Fuel injectors - how to clean (In7egrity)
This Snap-On gadget sounds pretty neat for doing the job! Do mechanics use this type of device when they clean injectors??
Old 11-29-2001, 07:59 PM
maxxdout's Avatar
nice suggestion Maybe you could find this contraption for us and let is know abut it. It seems intesting and i would love to learn more.
Old 11-30-2001, 01:36 PM
Dirt's Avatar
Default Re: Fuel injectors - how to clean (maxxdout)
Slick 50 Fuel System Treatment every 3000 miles at about $6US/bottle
Old 11-30-2001, 04:33 PM
zojirushi's Avatar
Default Re: Fuel injectors - how to clean (MmmVTEC)
How about Redline fuel treatment? I just bought a bottle today at pep boys for around 5 bux. Redline is supposed to be good, so why not their fuel treatment?
Old 11-30-2001, 04:36 PM
GTEater's Avatar
even A&H says its the best one they've ever tested
Old 11-30-2001, 05:07 PM
csufweed's Avatar
this is the correct way to clean the injectors!
Many shops will do this for you, but they tend to charge like $80, but it is a full fuel system clean. The bottles are good for maintenance in between these cleanings.
Old 12-03-2001, 06:45 PM
New User
michaelpr's Avatar
Default Re: Fuel injectors - how to clean (csufweed)
I paid a visit to the snap-on website. However, I was not able to find the tool mentioned above for cleaning the injectors.
Any suggestions?
Old 12-04-2001, 05:48 PM
New User
michaelpr's Avatar
Any information on the above mentioned contraption?
Old 12-04-2001, 06:15 PM
ingrate's Avatar
sorry about that.. haven't been on the board for a while.. here's the link:
http://buy.snapon.com/catalog/pro_de...re&dir=catalog
i almost laughed out loud when i saw the price!!! maybe you could charge all of your friends to clean their injectors
Old 12-04-2001, 07:35 PM
MrFatBooty's Avatar
Good lord!
Old 12-04-2001, 08:04 PM
InfamousRS's Avatar
Default Re: Fuel injectors - how to clean (MrFatBooty)
by golly, I would feel just like a real machanic if I had one of them fangled things!
Old 12-05-2001, 05:40 PM
New User
michaelpr's Avatar
Default Re: Fuel injectors - how to clean (BLK94RS)
Yes, I saw this item on the Snap-On page, but it is nothing like was described above. I was looking for something that I place cleaning fluid in and then running that through the injectors with the fuel pump disconnected. The item on the web page above seems to be a high pressure air cleaner.
Old 12-06-2001, 05:26 PM
New User
michaelpr's Avatar
Is there another device as was described above - other than this high air pressure machine?
Old 12-06-2001, 05:37 PM
cjohnson_2's Avatar
Dont you guys think that it needs to have some sort of pressure to force the cleaner through the injectors? Im guessing this is the device everyones talking about. You need fuel pressure to make your car run....
Old 12-06-2001, 05:40 PM
New User
Rain_man's Avatar
I recently took out my injectors and dropped them off at RC to have them cleaned and balanced since I had about 95k on the car. When they checked the injectors, they found that hey were perfectly clean and balanced too and just charged me 40 for the check. Not bad for 95k. I've used the redline stuff about 3-4 times over the life of the car and I guess it works. But if you have massive buildup I dunno if it would be effective enough.
Old 12-06-2001, 06:06 PM
ingrate's Avatar
yes that item is exactly what i was describing above.. "fuel injection system cleaner." that red thing opens up and you fill it half with techron and the other half with chemtool. then it has hoses that lead to your injectors that you just screw on. then you adjust fuel pressure on it to around 30-40 psi and start engine. takes about 20-30 minutes. HTH
movingIIshadow
30
02-29-2020 07:36 AM
boltnut
01-10-2005 04:11 PM
EK45VTi
10
09-21-2004 07:03 PM
HXvtec
03-17-2004 04:27 AM
allmotorls95
02-03-2003 09:01 PM
Quick Reply: Fuel injectors - how to clean
