Fuel Injector Plug Order?
Old 12-24-2008, 01:45 AM
I drive a G35, it's silver, surprised?
CARMA_626's Avatar
Default Fuel Injector Plug Order?
I think I made a bone headed mistake. I'm doing a full wire tuck and redoing my engine harness to clean things up a bit.
As I was cutting and resplicing wires, including my fuel injector plugs - I thought to myself "dont they need to be in specific firing order?"
Once I get around to installing my engine, I wont have any idea what fuel injector plug will go to which injector. What I should of done was mark each plug #1- #4 so that I know which injector it should go to. Oh well, too late now.
So what do I do now? How do I determine which plug goes to which injector? Or does it even matter?
Old 12-24-2008, 04:05 AM
IN VTEC's Avatar
Default Re: Fuel Injector Plug Order?
wire color then confirm with a continuity test to the ECU pin.
Old 12-24-2008, 04:26 AM
Man U FTW
Schister66's Avatar
This diagram gives the colors for each of the fuel injectors. You can ignore the resistor box since you're not going to be wiring one in. Also, left to right is passanger to driver's side just like you're looking at it from the front of the car
Old 12-24-2008, 04:18 PM
CARMA_626's Avatar
thanks guys!
Schister66 you are the man!
Old 02-13-2013, 11:26 AM
STN_Pat's Avatar
indeed.
thanks !
CARMA_626
12-25-2008 12:24 AM
NevinJoe
08-24-2008 06:10 AM
EeeJayEight
06-11-2004 03:14 PM
rock2447
02-10-2003 12:59 PM
ratherbewalking
01-01-2003 07:46 PM
Quick Reply: Fuel Injector Plug Order?
