axle, cv-joint???
Old 10-28-2003, 09:49 AM
BrownGSR's Avatar
Default axle, cv-joint???
When i am turning very slow (under 40) or cut the wheel very hard(like to get into a parking spot) I hear a click and clunk coming from my car. It seems to be only the left side any comments?
Old 10-28-2003, 10:12 AM
wcsinx's Avatar
Default Re: axle, cv-joint??? (BrownGSR)
A repeating click-clunk in time with your turning wheel (usually the outer wheel)? Or just a single noise?
Old 10-28-2003, 10:18 AM
BrownGSR's Avatar
Default Re: axle, cv-joint??? (wcsinx)
something sounds like it pops when i turn at relatively low speeds
Old 10-28-2003, 10:57 AM
au-gsr's Avatar
get under the car and look at the cv boots if they are gone then i'd be safe to assume that its the cv joint
Old 10-28-2003, 11:54 AM
BrownGSR's Avatar
Default Re: axle, cv-joint??? (au-gsr)
the boots look fine, there is no damage to anything that i can see underneath the car
Old 10-28-2003, 12:12 PM
wcsinx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrownGSR &raquo;</TD></TR><TR><TD CLASS="quote">something sounds like it pops when i turn at relatively low speeds</TD></TR></TABLE>
Pops just once right? ... could be tie rod ends, shocks/struts, worn suspension bushings, etc. Kind of hard to tell from here. See if you can duplicate the sound by bouncing the car in place with the wheels at full lock one way or the other.
Old 10-29-2003, 08:00 AM
BrownGSR's Avatar
i have a full prothane kit and new struts. just seems to do it when i am slowly turning. weird
samba_green_sol
12
07-23-2007 03:07 PM
SpoolFedEF
10
01-04-2006 07:19 AM
D16Z6_turbo
19
03-17-2005 11:37 AM
hyperlite1080
11
04-14-2004 08:24 PM
drvfast
09-10-2003 05:12 PM
Quick Reply: axle, cv-joint???
