Failed smog check!!! Help
Old 05-19-2008, 03:12 PM
Nicks95GSR's Avatar
Default Failed smog check!!! Help
I took my car to a test only smog check station and it ended up not passing. This was the first time I took my car to get smogged. (I've had the car for 2 years) The dude told me that it didnt pass cuz the NO (PPM), CO (%), and HC (PPM) were too high.
The HC(PPM) amount measured 146 and the MAX allowable emissions is 90
The CO(%) amount measured @ 0.58 and the MAX allowable emissions is 0.54
The NO (PPM) amount measuredn@ 2498 and the MAX allowable emissions is 711
It failed the 15MPH run
Passed the 25MPH run
The dude told me it mite have something to do with the PCV since it was modified. What else can it be?
Thanks!
Old 05-19-2008, 03:17 PM
boost'd_crx's Avatar
Default Re: Failed smog check!!! Help (Nicks95GSR)
cat and o2
Old 05-19-2008, 11:20 PM
Nicks95GSR's Avatar
Default Re: Failed smog check!!! Help (boost'd_crx)
I was thinking it might have been the cat since its old and rusted but wasnt sure.
Thanx
Old 05-19-2008, 11:21 PM
Nicks95GSR's Avatar
Do I need the original PCV or can I just leave it like that?
Old 05-20-2008, 06:45 PM
Nicks95GSR's Avatar
Anyone?
Old 05-20-2008, 07:53 PM
Dc2alldawaY's Avatar
take your pcv valve out shake it if it makes a sound its good slap it back in, and go get yourself a new cat, borrow a buddys, or if you know how to weld go get your self one of those short napa cats weld it on, dump your car then go test then cut it out.
Old 05-20-2008, 10:28 PM
inspiration's Avatar
Those are some pretty high numbers. Usually when I tell people to do this. Go buy Seafoam follow the directions, run gas on low, buy 2 anti-freeze gas line bottles put it in your gas tank, pump 91 octane Chevron half tank.
Go back there and smog your car. Should pass.
Old 05-21-2008, 06:53 AM
all-mtr-teg's Avatar
Default Re: Failed smog check!!! Help (inspiration)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspiration &raquo;</TD></TR><TR><TD CLASS="quote">Those are some pretty high numbers. Usually when I tell people to do this. Go buy Seafoam follow the directions, run gas on low, buy 2 anti-freeze gas line bottles put it in your gas tank, pump 91 octane Chevron half tank.
Go back there and smog your car. Should pass.</TD></TR></TABLE>
Make sure its the "HEAT" brand, yellow bottle, the red one doesn't have methanol.
Old 05-21-2008, 07:37 AM
Default Re: Failed smog check!!! Help (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">
Make sure its the "HEAT" brand, yellow bottle, the red one doesn't have methanol.</TD></TR></TABLE>
Yep.. That is the brand to use. Good lookin..
La Zona Imagery
05-23-2016 11:05 PM
beginmyhonda
14
12-13-2009 10:24 PM
zipoton
13
01-16-2008 06:26 AM
Ritchie
24
07-01-2007 07:30 PM
Blackhtch
46
12-30-2004 12:02 AM
Quick Reply: Failed smog check!!! Help
