exhaust manifold thread size
Old 01-08-2009, 07:08 PM
eastbayg's Avatar
Default exhaust manifold thread size
i just swapped my engine but do not have some parts. i need to know what size studs and bolts i need for the headers to mount to the motor exhaust manifold. i know what size socket i need, i need to know the actual thread size of the bolts and studs. some1 help?
Old 01-08-2009, 07:36 PM
PatrickGSR94's Avatar
Default Re: exhaust manifold thread size
Luckily my Helms is handy.
8 x 1.25mm thread.
Old 02-03-2009, 11:40 PM
dootsDA9's Avatar
8 x 1.25mm thread.
is that the same size for the three bolts that connect to the down pipe? I have a big exhaust leak and wondering what size socket that will fit..my guess would be 14mm? two are studs connected by nuts but one looks like it should be connected by a bolt..any help is appreciated..
Old 02-04-2009, 04:21 AM
It's probably the same, and they should be 12mm nuts (6mm thread is typically 10mm bolt head).
Also, the stock manifold and A-pipe are held together by 3 studs w/ nuts on them, no bolts. Sometimes the nut likes to fuse itself to the stud, and the whole nut/stud combo comes out of the manifold, and it's a huge PITA. Even when I try to shoot them off quickly with my impact, the stud still comes out of the manifold.
Old 02-04-2009, 10:30 AM
dootsDA9's Avatar
ok cool..thanks alot for the help..
Civic Racer X 7
08-29-2014 07:37 PM
88EDHatch
05-18-2010 08:34 AM
Rory Breaker
09-15-2005 05:22 PM
DEVIN22CBR
02-12-2004 02:35 PM
Quick Reply: exhaust manifold thread size
