engine make wierd whistle noise
Old 03-11-2002, 07:15 PM
lazyguy's Avatar
Default engine make wierd whistle noise
im pretty sure its a vaccum leak but ive checked and cant seem to find it, its a highpitched whistle and it pisses me off
Old 03-11-2002, 07:27 PM
Chris's Avatar
Default Re: engine make wierd whistle noise (b18cURmama)
thats nice..
Got a question? If so, please let us all know your setup, so we might help you.
Old 03-11-2002, 07:30 PM
New User
Aeka GSR's Avatar
take your turbo out, that should solve your problem!!!
=P
Old 03-11-2002, 07:33 PM
lazyguy's Avatar
Default Re: engine make wierd whistle noise (Chris)
95 gsr skunk2 mani, apex n1, jdm 4-1, fpr, vafc, p28 mugen
Old 03-11-2002, 07:35 PM
Chris's Avatar
intake? (CAI?)
Old 03-11-2002, 07:37 PM
lazyguy's Avatar
no its short ram and its not when i give it gas its all the time, at idle, whenever
Old 03-11-2002, 07:38 PM
Chris's Avatar
thats the info needed.... remember, the more you tell us the more we can help.
Now, you should get an educated response.
Old 03-11-2002, 07:54 PM
New User
Aeka GSR's Avatar
i get a whistle when im giving it gas after a shift, is that what you are talking about?
Old 03-11-2002, 08:15 PM
New User
Pinhead's Avatar
Default Re: engine make wierd whistle noise (Aeka GSR)
I say tranny problem
Old 03-11-2002, 08:22 PM
New User
Aeka GSR's Avatar
Default Re: engine make wierd whistle noise (Pinhead)
who me? i hope not, ive heard the whistle for as long as i had the car (1 year), the only problem with my tranny that i know of is the 5th gear syncro is fucked. Plus I put in a new clutch about 6 months ago.
Old 03-11-2002, 08:45 PM
Keyed ITR's Avatar
If it's supposedly the intake, it's not. It's the throttle body's butterfly scraping whenever it opens for air. The throttle body obviously opens when you accelerate, so is it when you accelerate?
Old 03-11-2002, 08:52 PM
project_DC2's Avatar
Default Re: engine make wierd whistle noise (Keyed ITR)
same problem here! The whistle noise starts when my car idles! If it runs I doubt you can here it if you have an aftermarket exhaust!
Hold on lemme check..I think it is the throttle body!
Old 03-11-2002, 09:03 PM
Default Re: engine make wierd whistle noise (project_DC2)
it should be the throttle body! When you look on your engine bay! There should be a sensor plug on top of the TB! Right next to it, you should see a screw! Get a flat head and turn it either left and right to adjust it!
Do this while ur car is running! Play with the adjustment and it should lower the whistle noise! You just got to play with it! Just dont fuc!@# up the screw w/ the flat head!
Old 03-11-2002, 09:06 PM
thats nice..
LOLZ! Chris!
Old 03-12-2002, 08:18 AM
lazyguy's Avatar
yea i dont hear it when im driving cuz of the exhaust, but its not the intake like i said its all the time its a loud high pitched whistle even while the car is just sitting there
Old 03-12-2002, 10:11 AM
Fooser's Avatar
Check the tubing the runs from the intake to the valve cover. If thats pinched at all it could cause a whistle noise. Make sure the tubing is good. Then if that checks out I would move on to the intake manifold and see if thats the cause. Intake cleaner is always good while your in there. theres an adjustment screw as well that you can try.
[Modified by Fooser, 7:12 PM 3/12/2002]
Old 03-12-2002, 10:39 AM
lazyguy's Avatar
Default Re: engine make wierd whistle noise (Fooser)
the tubing is not bent, so u say try the idle screw?
Old 03-12-2002, 11:04 AM
Fooser's Avatar
Hard to say its coming from the throtle body. So you removed the hose and checked it. just blow in it to see if theres anything obstructing it.
if not then your going to have to pop your hood and have your car running to pippoint where the noise is coming from.
The idle screw will only adjust your idle speed. I dont think thats the problem from what I'm hearing. You said you hear the noise throughout the rpm band?
Have a friend help you out with this. have him sit in your car and rev your engine and you try to hear where the noise is coming from. Its probably a leak from somewhere. Just keep looking around and you will probably find it.
I remember my anti-lock system was squeaking because it came loose. I had to tighten it down again. squeak was gone. So its hard to say what the noise actually is unless I heard it.
Oh ya check your belts to. if they are not tentioned correctly and are slipping they will definetly cause a high pitch squeak.
[Modified by Fooser, 8:09 PM 3/12/2002]
Old 11-12-2008, 04:21 PM
civicdreamin's Avatar
so im having a similar problem i think.. its a 2000 integra gsr sedan.
heres some videos of when its cold, and after its warmed up..
I really need help figuring out whats making the whine in the engine.
Any help is great
This is Cold engine.
This is warmed up
It seem like it comes and goes sometimes and maybe not as loud sometimes..
it had had recent timing belt changed maybe 10k or so ago and trans flush..All service as been kept up to date.. 114000 miles and runs great..
ps i did a search and this thread is the only one i found on this topic back from 2002.. it does not look like anyone came to a conclusion on what it is.. plz help
Modified by civicdreamin at 5:34 PM 11/12/2008
Old 11-12-2008, 05:18 PM
I'm Huge In Japan
VegasInvasion's Avatar
Default Re: engine make wierd whistle noise (civicdreamin)
I know exactly what it is.
Clean your FIT valve, it's full of sludge.
Old 11-12-2008, 05:55 PM
great so where do i find that, and What is a fit valve.. thank you vegas
do u mean pcv valve?
Old 11-13-2008, 08:12 AM
plz help.. im worried this could lead to other issues..
thank you for you time
Old 11-13-2008, 10:55 AM
ok since i cannot pm vegas does anyone know what a fit valve is?
Old 11-13-2008, 10:57 PM
I'm Huge In Japan
Default Re: (civicdreamin)
Yeah I'm not a PM kind of guy, sorry. Haven't quite figured that out yet.
Fast Idle Thermo valve, it regulates idle during cold temperatures to warm you up quicker. I'm assuming you have a B-series, so it's likely you have a FITV. It should be the unit attached under your throttle body, there's small coolant hoses connected to it.
Anyway after you unbolt it and remove the coolant hoses (which might require removing the throttle body first unless you have stringy contortionist fingers), remove the screws from the end cap. You'll see a round white ring with grooves, use a screwdriver and carefully un-twist the cap (mind the spring). The rest is pretty self-explanatory. Then just clean it out with intake cleaner until it's shiny and new, and hope you remembered how it goes together.
If I'm totally off on this let me know, we'll figure something else out.
Old 11-13-2008, 11:02 PM
I'm Huge In Japan
PS
Don't worry, an intake squeal isn't life-threatening.
Quick Reply: engine make wierd whistle noise
