bspt or metric
bspt or metric
Car is 96 GSR
What is the adapter I need to "T" the EDC sensor... It's for an autometer water gauge... I'd like to keep the original sensor too...
1/8 bspt to 1/8 npt?
anyone knows?
anyone knows?
Re: bspt or metric
pretty sure its 1/8bspt just like the oil pressure sensor. i think most people just use npt with some extra teflon tape. if you really want an adapter you can get one from mcmaster http://www.mcmaster.com/#4860k141/=5gicy2 i think it will be tough to find a tee piece with all the right sizes and also there is limited space to tighten a bulky tee fitting.
alternatively you could get a radiator hose adapter off ebay for pretty cheap
Re: bspt or metric
what i don't like about hose adapter is that it dosen't read head temp... It's on the other side of the thermostat...So if the thermostat jam...
Re: bspt or metric
your right... I'd be curious to see that set up... anybody have a picture?
But I would still want to know the answer about my first question... I might try that route first
Re: bspt or metric
1/8bspt but again its gonna be tough to find all the right adapters and everything. i searched mcmaster for at least an hour looking for some kind of bspt -> npt tee with no luck. also you would need to be careful of the added weight of adapters and tees, it could crack the head similar to when people tee for turbo oil lines in the block
Re: bspt or metric
Autometer part 2269... It's something like 12$ http://www.autometer.com/cat_accesso...il.aspx?vid=59.
I'm alwready "t" behind the block at the pressure switch for oil pressure... I have put a 6 inch highpressure rubber hose before the "t". Have 40 days of track with that set up last summer and never had any issue...
Re: bspt or metric
neocrynym
07-02-2006 05:40 PM
asiansgoweeee
11-03-2004 08:03 AM
