Ecu codes with step down harness
Yo Honda tech watsup.ive always delt with obd 1 civics never had a kick down harness..whatever......I have a 96 integra now ..it has a kick down harness and chipped po6 ecu..my check engine light is on.how do I go about check codes.i try to plug in scanner and figuring it was a obd 1 ecu it didn't communicate with ecu....obd 1 you have jump the plug under the glove box....any help would be appreciated....
Re: Ecu codes with step down harness
Anybody ?.?200 hits and No suggestions... I thought step down harness was a thing from 2000..figure it be a piece of cake here...thnx..somebody know something....
Thanks for the info parts pro.. I know all this.. The problem I have is a kick down harness obd2 integra with a po6 computer... I can't hook up scanner to obd2 port. So I try flashing it also no luck.. I come to realize though that my maintenance req lite is on.. I'm figuring that's the check engine light though being that I don't see the traditional light like the civics had... But thanks for the info..at least some tried to pitch in some info....thanx once again.
MrWestCoast
03-18-2013 03:04 PM
chippinpressure
Engine Management and Tuning
01-14-2010 05:47 PM
kcvi3tstyl3
04-20-2009 06:17 PM
