Dyno Tuning Results
Dyno Tuning Results
Just tuned my GSR with a JRSC, Im happy with the numbers.
Dyno Dynamics
Before
WHP-186
After
WHP-201
These are on a Dyno Dynamics dyno, which read roughly 13% lower than a dyno jet.
Dyno Jet
Before
WHP-210
After
WHP-227
Computer Estimated DD crank hp - 256
gmoore
Dyno Dynamics
Before
WHP-186
After
WHP-201
Dyno Jet
Before
WHP-210
After
WHP-227
gmoore
Re: Dyno Tuning Results (AllmotorJunkie)
Thanks. 14.8 , we think its a traction problem. Thursday we are running again, Im looking for high 13's. Id post the graphs but I cant find the damn ac adapter for my scanner.
gmoore
gmoore
Re: Dyno Tuning Results (96dc2)
The curve is unbelievable, it just keeps pulling and pulling without a dip. Torque was at 167 I believe but we ran A/F and whp on the graphs. However I saw no jump for V-tec, but I know I heard it. I gotta find that adapter.
gmoore
Not to highjack my own thread, but a guy at the shop dropped by and had "V-TECH" tattooed on his arm.
gmoore
Re: Dyno Tuning Results (tegunderpressure)
Shoulda gotten a picture...v-tech?! Awesome!!!!
What boost level was this at? What did you use to tune? Tuning makes SUCH a difference with these setups! Where was your vtec set?
Oh and didnt you have a problem recently with a chatter or charger problem, what ever happened with that?
Re: Dyno Tuning Results (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver »</TD></TR><TR><TD CLASS="quote">Shoulda gotten a picture...v-tech?! Awesome!!!!
Oh and didnt you have a problem recently with a chatter or charger problem, what ever happened with that? </TD></TR></TABLE>
Yeah, but I didnt have my digi, I would have.
This is at 7-8 psi with the JR 8lb pulley.
They tuned timing and fuel with a Vortech SFMU. I got all my gaines from advancing the timing 2 degrees.
Vtec is at the stock turnover.
Yeah, it was chattering awhile back, but I shipped it off and got it back and reinstalled, so I think Im good.
gmoore
gmoore
What did they determine to be the problem? Was it under warranty or did you pay...and how much? Just FMI.
227/167 is great man...torque is very nice. I bet if you dropped VTEC and perfected ignition/fuel throughout, you would see an even smoother graph with better numbers. Hint...get a Hondata already...
Good numbers man, you should be well into the 13's with that as soon as you can get used to driving it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver »</TD></TR><TR><TD CLASS="quote">What did they determine to be the problem? Was it under warranty or did you pay...and how much? Just FMI.
Good numbers man, you should be well into the 13's with that as soon as you can get used to driving it!</TD></TR></TABLE>
See, thats what I thought. But when I said the best I, and many other friends could pull was a 14.8, he said he thought that was correct.
All in all I spent aton on fixing the blower. Ill PM you the whole story.
Yeah, I know hondata makes a huge difference, but the price has always scared me away. Chet, however, last night said I could get into a system for 500 tuned. Is that true?
gmoore
gmoore
I dont know about 500 tuned, that is low even with a used system and DSM's. The S200B system will run you $450, and the S100B a bit cheaper...tuning is usually around $175-$200/hr, not including installation or injectors and no partial tuning either.
14.8 with 210whp...no way does that add up to 14.8. You figure there are GSRs with 160whp running 14.8's. 210/150 should be solid 13's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver »</TD></TR><TR><TD CLASS="quote">I dont know about 500 tuned, that is low even with a used system and DSM's. The S200B system will run you $450, and the S100B a bit cheaper...tuning is usually around $175-$200/hr, not including installation or injectors and no partial tuning either.
14.8 with 210whp...no way does that add up to 14.8. You figure there are GSRs with 160whp running 14.8's. 210/150 should be solid 13's.</TD></TR></TABLE>
Gotta agree with you bro',
he should be in the 13's for sure,
my car has never been tuned, and i hit a 13.5 the first time i took it to the track.
Modified by RuffGsR at 1:32 AM 6/26/2003
Re: Dyno Tuning Results (RuffGsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuffGsR »</TD></TR><TR><TD CLASS="quote">
Modified by RuffGsR at 1:32 AM 6/26/2003</TD></TR></TABLE>
how much power are you putting out? any weight reduction?
jpenman50
04-05-2006 03:32 AM
