Do you torque a aluminum flywheel with factory torque specs?
Old 02-16-2009, 07:54 PM
Jk_DC2's Avatar
Default Do you torque a aluminum flywheel with factory torque specs?
Before i do the install i want to know if you use the factory torque spec to torque a aluminum flywheel. I have a 96 RS. Thanks
Old 02-16-2009, 07:57 PM
MumBleZ_94gsR's Avatar
Default Re: Do you torque a aluminum flywheel with factory torque specs?
im pretty sure but dont take my word on that...
lol i dont think i was much help
Old 02-16-2009, 08:34 PM
Jk_DC2's Avatar
lol its cool. I just got a great deal on a 7.5lbs fidanza flywheel and a stock exedy clutch for $250. So anyone else that can help me. really appreciate it. Also if it is factory torque do i put lock tite?
Old 02-16-2009, 09:20 PM
They let me pick
mrdeadman's Avatar
Does the manufacture of the flywheel recommend any torque settings? I would call and ask them to be 100% sure.
Old 02-16-2009, 09:33 PM
Circuit Star-29's Avatar
Yes. And just to make sure the flywheel seats properly I took a torch to the mating surface of the flywheel to expand it. Once it cools it will be that much tighter around the crank.
Old 02-16-2009, 09:56 PM
Jk_DC2's Avatar
Ok so it is factory torque spec huh. Anybody can second that before i begin? Its 72lbs of torque right?
Old 02-16-2009, 10:34 PM
What ever the manual says. And don't forget the torque sequence
Old 02-17-2009, 12:22 AM
racebum's Avatar
i have that same combo on my R, the gripforce deal? anyway i went 90lbs with ARP bolts, DO use RED threadlock. this wheel chatters like mad till the clutch breaks in. 80lbs to 72lbs would probably be alright too provided you use red. also clean off the crank snout and consider changing the main seal if your car has over 120k and is on the OE seal
Old 02-17-2009, 07:09 AM
Jk_DC2's Avatar
What are ARP bolts? can i just use my stock flywheel bolts?
Old 02-17-2009, 10:40 AM
racebum's Avatar
yes, arp bolts are just stronger. i bought them because my factory bolts had a few mangled threads.
Dave_Dc2
12-12-2008 08:06 AM
1 sLoW hAtCh
05-01-2006 10:44 PM
madswapper
05-01-2005 05:01 PM
AllMoToRB18c
06-29-2003 11:24 PM
Quick Reply: Do you torque a aluminum flywheel with factory torque specs?
