DIY: Replace power steering hose (Pressure) - Honda-Tech
Old 06-12-2009, 08:38 AM   #1
kroze's Avatar
Default DIY: Replace power steering hose (Pressure)
My pressure power steering hose is leaking so it's time to replace it. I didn't know how simple this job is but a lot of repair shop want to charge 2 hours (Approximately $180 after tax) to replace this freaking hose. While you're at it, I suggest you replace the return line of the power steering as well, it's really cheap & easy. But anyway here's the guide for the Pressure hose replacement.
Tools needed:
- 10mm Socket & Extension
- Ratchet
- 14mm Metric Flare nut Wrench
- 9/16 Standard Flare nut Wrench (the new hose from autozone uses 9/16 instead of 14mm)
- Adjustable wrench (not in picture)
Jack up the car
Remove these 2 bolts (10mm)
Remove all bracket holding the hose (10mm) Not in this picture because I've already removed them and thrown them away. You can reuse them if you bought the rubber bushings for the new hose, if not do what I did and throw them away :dunno420:
Unplug the sensor, There's another bracket holding the line around there, you'll need an extension to remove the 10mm bolt (or crawl under the car and feel where the bolt is get it from there, I've removed it and thrown it away as I didn't buy the new rubber bushing for the bracket.
Now crawl under the car and use your 14mm flare nut wrench to remove this bolt.
With the old Power steering hose out, use an adjustable wrench and remove the old sensor & put it into the new hose.
Install new hose in reverse order & you're done!!
Here's the old & leaking hose for reference.
kroze is offline   Reply With Quote
Old 06-12-2009, 12:32 PM   #2
HONDRETTI's Avatar
Default Re: DIY: Replace power steering hose (Pressure)
good job. i had to do this last year when i recovered my car, for some reason the feed line was leaking. you ABSOLUTELY need a line wrech to remove that nut, i'll vouch for that.
HONDRETTI is offline   Reply With Quote
Old 01-12-2012, 05:30 AM   #3
The pictures no longer work, I am currently trying to install a power steering hose on a 92 prelude any help is greatly appreciated.
whitakjc989 is offline   Reply With Quote
Old 01-12-2012, 12:20 PM   #4
DirtyDA9's Avatar
Because it's from 2009. I love how the only picture working now is of Jude Law or whoever lol.
DirtyDA9 is offline   Reply With Quote
Old 04-06-2012, 10:24 PM   #5
ZombiePharoh's Avatar
really funny hahah. heres the tools you need. a scarf. jack up the car. cats.
ZombiePharoh is offline   Reply With Quote
Old 04-06-2012, 10:28 PM   #6
racebum's Avatar
quality write up right hea
racebum is offline   Reply With Quote
Old 04-15-2013, 11:53 AM   #7
This thread sucks lol
Bouckaroo is offline   Reply With Quote
[DIY] How to remove a B-series cylinder head Corksil Honda Civic / Del Sol (1992 - 2000) 59 10-18-2016 09:54 AM
96-00 Civic Scarebird brake conversion write up. CerealWars Honda Civic / Del Sol (1992 - 2000) 85 07-03-2016 05:44 AM
How-To (JDM) 1" ITR MC/BB into Civic install pdiggitydogg Honda Civic / Del Sol (1992 - 2000) 21 04-27-2012 07:50 AM
D.I.Y Replacing CMC Type-Spaz Acura RSX DC5 & Honda Civic EP3 0 03-30-2011 03:06 PM
Turbo/ECUs/OEM/Recaro/C West/RevHard codyellis For Sale 24 06-16-2009 08:15 AM
Tags
2000, accord, honda, hose, install, leaking, line, power, pressure, pressurized, remove, replace, replacing, steering, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
