difference in exhausts
Re: difference in exhausts (mrdeadman)
i beleieve the only difference is the cat, the LS o2 sensor is on the header, and the GSR sensor is actually on the cat, you could run into some problems towards the back axle, but im not sure...
SEARCH, this topic has been covered a million and a half times...
ยป Search Results
Your search for ls gsr exhaust differences returned 5 results.
https://honda-tech.com/zerothread?id=1306573
etc...
ยป Search Results
etc...
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman »</TD></TR><TR><TD CLASS="quote">what's the difference between a ls exhaust and a gsr's? will a gsr exhaust fit an ls without modification?</TD></TR></TABLE>
A '94+ LS exhaust will fit a '00-'01 GS-R and vice versa. The '94-'99 GS-R exhaust is longer, and will not fit an LS or newer GS-R without modification.
