motor install fees??
Old 05-23-2005, 12:35 PM
hondatuner20's Avatar
Default motor install fees??
how much does it cost to have a shope drop in a motor??
Old 05-23-2005, 12:57 PM
Lan
Lan's Avatar
Default Re: motor install fees?? (hondatuner20)
What motor, what car?
Old 05-23-2005, 12:59 PM
Default Re: motor install fees?? (Lan)
b18c1 or b18c5 in a DA
Old 05-23-2005, 01:00 PM
Takumi Fujiwara's Avatar
swaps in the new england area charge between $600 and $1000. I'm sure shops that do swaps more often will charge less.... just get some friends together one day and do it in the garage.
Old 05-23-2005, 01:01 PM
Lan
Lan's Avatar
About 7-1000 in cali
Old 05-23-2005, 01:02 PM
Lan
Lan's Avatar
If you got a type R motor probably more because people hate
Old 05-23-2005, 01:18 PM
why do people hate swapping type r motors
Old 05-23-2005, 01:23 PM
Lan
Lan's Avatar
I am saying that they would hate on you for having one. Cause they probably want one themselves
Old 05-23-2005, 04:25 PM
do you know any good cheap places (cites) that i could buy a b18c5 off of?
Old 05-23-2005, 05:00 PM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">do you know any good cheap places (cites) that i could buy a b18c5 off of?</TD></TR></TABLE>
this is where i bought mine
http://www.hmotorsonline.com
Old 05-23-2005, 05:59 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">why do people hate swapping type r motors</TD></TR></TABLE>
because they dont have one.. thats why
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo &raquo;</TD></TR><TR><TD CLASS="quote">drop it in yourself for way cheaper</TD></TR></TABLE>
if he doesnt know how, this isnt a bad way to go.. plus if you go to a repratable(sp) shop, they will warranty there work..
Old 05-23-2005, 07:17 PM
integra-evan's Avatar
i know the auto store/shop i work at is 300 to remove old, 300 to put in new. so about 600
Old 05-24-2005, 02:57 AM
Default Re: motor install fees?? (DA9-hari)
did you buy th b18c 94-97 complete swap?? if so did u have to end up buying some other parts??
Old 05-24-2005, 03:48 AM
OBD1Kenobe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">how much does it cost to have a shope drop in a motor??</TD></TR></TABLE>
FSM - $70
Labor - 8hrs
Learning how to swap an engine - Priceless....
Old 05-24-2005, 04:00 AM
Deucedeuceteg's Avatar
Default Re: (skylinedo)
nice JDM site nice engines ::droolin::
Old 05-24-2005, 06:12 AM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">did you buy th b18c 94-97 complete swap?? if so did u have to end up buying some other parts??</TD></TR></TABLE>
yeah i got the 97 spec complete swap. i had to buy placeracing mounts, and hasport cable to hydro conversion kit in order for me to run the itr tranny
Old 05-24-2005, 07:03 AM
Str8clowninGSR's Avatar
usually cost engine price + about 600-700 labor.
anybody know if i can put a b18c5 head on a b18c1, i bent all my valves and im just going to rebuild a little bit stronger. i need some advice
Old 05-24-2005, 09:02 AM
HARI.'s Avatar
Default Re: motor install fees?? (Str8clowninGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Str8clowninGSR &raquo;</TD></TR><TR><TD CLASS="quote">usually cost engine price + about 600-700 labor.
anybody know if i can put a b18c5 head on a b18c1, i bent all my valves and im just going to rebuild a little bit stronger. i need some advice</TD></TR></TABLE>
ofcourse you can
Old 05-24-2005, 02:40 PM
so how much did all those extra parts and the motor plus install end up costing u?
Old 05-24-2005, 04:16 PM
SPEED FoRCE's Avatar
its about 7 to 8 hours of labor, but you have factor in any wiring that has to be done, unless you are including a harness, then they add the labor of adding that in, some places will do it for cheap to add that, since the engine will be out already. Up north they charge about 80 an hour to do a swap, I charge about 350 to 400 depending on what needs to be wired and I hook people up on some stuff.
Old 05-24-2005, 05:02 PM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">so how much did all those extra parts and the motor plus install end up costing u?</TD></TR></TABLE>
i spent an extra $500 just for the parts alone. my buddy and i installed it
Old 05-25-2005, 02:55 AM
ok.. so would u say about 4900 is what ill spend for the motor and parts and swap?
Old 05-25-2005, 04:39 PM
where did u get those place racing motor mounts from??
Old 05-25-2005, 05:55 PM
revautousa's Avatar
I think its 5-600 for drop in
Old 05-25-2005, 05:59 PM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">where did u get those place racing motor mounts from??</TD></TR></TABLE>
from http://www.placeracing.com
Quick Reply: motor install fees??
