crankshaft position sensor issues
Hey guys. Ive been getting a recurring engine code saying my Crankshaft Position Sensor is faulty. After reading about it, I can tell that its basically located on the left side of the engine under the main crank pulley. Would getting to it be just a matter of taking off the left tire? Or do I need to do this from inside of the engine bay? Im thinking it might just be covered in oil/dirt, so I want to check it and disconnect it before buying a new one. Any tips on this?
Re: crankshaft position sensor issues
you have to remove the crank pulley and belt covers to get to it. if you have all your belt covers, i doubt it is covered in oil or dirt. though you should check to see if the wires are rubbing against the alternator belt (people forget to clip it back on to the bracket)
Ok, so what are some things I should look for on it before ordering a new one. Its not exactly cheap so if mine is still good I want to hold onto it. Im guessing I should just look for any electric connector issues such as corrosion? If theres nothing visibly wrong with it should I just assume its "Dead"?
Technical Hero
That's not the crankshaft position sensor its the crankshaft fluctuation sensor. The crankshaft position sensor is inside the distributor and if its bad you'll need to replace your distributor. What is the code exactly?
I forgot the exact code but I am 100% sure that the code was for the POSITION sensor... not fluctuation. I have read in various places though that the crank position sensor is located under the main crank pulley... I've even had someone point it out on a b18 that was out of a car. Could it be that I was looking for a fluctuation sensor the whole time?
what usually happens is the wires get rubbed against the alt belt or the wires can get pinched, this is what happened to mine, i thaught it was bad and got a new one then saw the wires were cut by the alt belt, any ways its a lil work to get to it but if its visually looks good then it might be dead but i havent heard of them dying ever. I have like 3 laying around so if you need one lmk ill sell one for hella cheap for you and they are in working cond.
the fluctuation sensor is located behind the crank pulley, as stated.
crank position sensor is located in the distributor.
you'd better pull the code before making any repairs
here's proof for you, since you've been misinformed. look at the obd2 distributor pin out. pin2 and 5
http://www.phearable.net/tech/wiring/distpluglegend.jpg
http://en.wikipedia.org/wiki/Crank_sensor
http://www.ehow.com/facts_7711805_cr...on-sensor.html
http://www.webanswers.com/automobile...ocation-155b40
Everything I searched seemed to point to the engine block near the crank pulley/flywheel. If it is in the distributor like youre saying, why do I have to replace the entire distributor? Thanks again for the help
Are you obd1? If you are, you don't have a fluctuation sensor
I think the crank fluctuation sensor is attached to the oil pump? Google obd2 pumps
You could replace the crank position sensor inside the dizzy, but you can't buy the sensors alone. You would have to buy a new distributor and either use it, or swap the internals
You still haven't given us the exact code. Make sure what it is before you waste your own time
http://www.drivewire.com/vehicle/acu...W4b7a599a692e4
I will pull the code and post it as soon as I can. I am just getting so much conflicting information. The guy a few posts up even offered to sell me the Crank Position Sensor, so they must be available by themselves without an entirely new distributor.
none of those links are of any use. all they do is explain what a crank sensor is. they aren't specific to your vehicle.
the divewire link is showing a crank fluctuation sensor. whether it's labelled as such or not.
here's another pic of the ckf (crank fluctuation) in this link
http://www.team-integra.net/forum/11...lem-fixed.html
Like Jason said, thats a Crank Fluctuation sensor.
Anyone who tells you 'they sell crank position sensors individually' is confused by a crank fluctuation sensor.
Get the code first, and ignore what you read. Lots of people are mis-informed.
Thanks alot guys.. heres another link selling them labeled as a position sensor:
http://www.autopartswarehouse.com/sh...a/integra.html
This is terribly ****ed up and misleading...
and this was posted in here earlier:
Good thing you guys stopped me before I started tearing **** up Like I said Ill post the code soon.
^ Wow I cant believe Beck Arnley is mis-informed as well. Lots of people are.
Get the code! You better hope its the crank fluctuation sensor, since it is cheap and easy to replace. The Crank position sensor requires rebuilding or replacing the dizzy.
best of luck!
best of luck!
and they're calling it a crank sensor because it still is a hall effect sensor which detects abnormal movement of the crank. fluctuation. detects misfires for the most part. the crank position sensor is more to allow the pcm to know whether the crank is rotating or not.
it really depends on the exact code you're throwing
LOL if were all missinformed then why does my Honda Shop manual And Alldata a car Repair Software Used by Tens of thousends of repair shops and 90% of car dealers including Honda
all call it a Crank Position Sensor
doesn't matter. where's the cfp then?
why on the distributor pin out is there an output v and ground for ckp?
tell you what, if i get a ckp code, i'm not probing or replacing the cfp
Technical Hero
CPK is located inside the dizzy. Your car will shut off occasionally at first and then it will shut off after a couple of minutes of running if you dont take care of that. You basically need a new dizzy. Check the o-ring inside the dizzy and make sure oil is not getting in there too.
Technical Hero
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Check the code
4 = Crank position sensor
54= Crank fluctuation sensor
Check the code
