LS/Vtec what should my fuel press be around?
Engine is a LS/Vtec with JDM type R cams. The car was tunned with 750cc injectors. I just put in a walbro fuel pump. (part by part getting ready for a turbo)
I'm now getting too much fuel so I picked up a fuel pressure regulator. I was wondering if you guys knew around what fuel pressure I should be running? Maybe some numbers on what a stock GSR or type R run would help give me something to start at.
Re: LS/Vtec what should my fuel press be around?
Damn 60 is kinda high lol, Id do 55 max. Honda's fuel pressure on a b18b1 is 40-47, B18C1 is 48-55, and B18c5 is 47-54 according to the Helms Service Manual
If your only getting 35-40 psi it sounds like you got some problems. I actually had a friend with a factory manual and it had just slipped my mind. The book says:
B18B 40-47 psi
B18C1/C5 47-54 psi
with fuel press vacume hose disconnected and pinched
B18B 43 psi
B18C1/C5 50 psi
with pressure regulator connected
B18B 40-47 psi
B18C1/C5 47-54 psi
B18B 43 psi
B18C1/C5 50 psi
anyone know a good psi setting for an ls/v on stock injectors with a walbro 190FP? 45psi seems to be a little to rich for me....at that setting my wideband at idle reads about 12.4
im running an ls/vtec with b16 head..with it at idle im at 32 on stock injectors and walbro 255 and it runs perfect. when you take the vaccum off it should be 50.
i was at stock before and my **** ran lean as hell...at idle around 15.5 and WOT sometime 17.4....sometimes it wouldnt even read it would go to 18 then go blank(3 blank lines) lol
yeah i need to get me a wide band.. bout to go up to some skunk2 pro1 with itr springs and retainers.. adjustable aem cams..im excited.. but im on s300 so my fuel is dailed in a bit tighter right now..so 32 when at idle and im running stock fuel rail and aem fpr..also make sure your idle screw on your tb is good, had a friend that had the idle screw turned all the way to the right and he ran lean unitll we opened it up a bit...just a thought
I have a ls vtec turbo and I have fic1000cc injectors and just put a 255 walbro im trying to figure out what my fuel press should be
The stock FPR is good for over 600 hp. Im only at 350 still using stock FPR.
