Code P1399 & P0302 - Anyone figure P1399 out?
I have a 2000 Integra GS-R. It has code P1399, yes it is code. It is not their manual. Along with that code, it is showing P0302 - Cylinder 2 Misfire.
Here are the given symptoms in the Integra Manual:
- Ignition System
- Fuel Supply System
- MAP Sensor
- IAC Valve
- Contaminated Fuel
- Valve Clearance
In the morning, I am going to check and change out the distributor with my other 2000 GS-R, do a valve adjustment, change plugs and reset the timing.
I have searched every forum and all the answers and posts I find are never solved. They just end with no information and people telling them that P1399 is not a code, when indeed it is, just not something we have access too.
If anyone has had this problem and solved it with success, please chime in.
Thanks
- Ignition System
- MAP Sensor
- IAC Valve
- Contaminated Fuel
- Valve Clearance
Thanks
