CODE P1337 help
Old 07-25-2007, 12:54 PM
Emmanuel2112's Avatar
Default CODE P1337 help
Im trowing code P1337 i belive its for - Crankshaft Speed Fluctuation Sensor No Signal. Need help my car is acting up real bad
Old 07-25-2007, 01:23 PM
Default Re: CODE P1337 help (Emmanuel2112)
NOBODY can help me
Old 07-25-2007, 05:59 PM
NOBODY HAS GOTTEN THIS CODE FIXED.
Old 07-25-2007, 06:28 PM
how do i fix this problem. Ive search and it seems nobody posts up hw they fix it. I need help
Old 07-25-2007, 07:27 PM
blkb18's Avatar
Search "P1337", it came up with more than 20 topics. Sounds like you need to check your crank sensor, located behind the lower timing cover. I am pretty sure the wires come out from behind the cover and you can ohm check it at the connector without taking off the timing cover.
Old 07-25-2007, 09:13 PM
Default Re: CODE P1337 help (blkb18)
yea but none of them actually says how they solved it
Old 07-26-2007, 08:37 PM
Old 07-26-2007, 08:55 PM
g2daturbo's Avatar
WHAT YR IS THE CAR... SOME YEARS THE CRANK SENSOR IS DOWN BELOW LOWER TIMING COVER... OTHERS IT IS PART OF YOUR DISTRIBUTOR LET ME KNOW AND ILL BE GLAD TO HELP U OUT
Old 07-26-2007, 09:07 PM
Default Re: CODE P1337 help (g2daturbo)
96' SE. I just changed the distibutor becuz the crankshaft position sensor was bad
Old 07-27-2007, 09:14 AM
help
JD466
05-16-2017 05:34 AM
T9U4ReBgO
05-18-2008 07:09 PM
civicboisi
09-26-2004 06:17 PM
Quick Reply: CODE P1337 help
