Clutch squeak..
Old 02-12-2008, 11:06 AM
dimwitrj's Avatar
Default Clutch squeak..
Ok so when my clutch pedal isn't pushed in it squeaks, kinda of sounds like a cricket chirping. It doesn't matter if it's in neutral or in gear and seems more louder when the weather's cold.
My question is what do you guys think is causing the squeaking? My first thought was the throwout bearing but after a little talk with a mechanic that gets parts from my work (Kragen ProShop) if it were the throwout it would squeak when the clutch pedal is pushed in. He says it may be the pilot bearing.
Also when I got my new clutch set put in (bought car with a blown clutch) I noticed that a packet of grease that came with the set wasn't even touched when they were finished. As far as I know, this packet is to grease the shaft and not the bearings..?
TIA for the input.
Old 02-13-2008, 06:44 PM
lmike6453's Avatar
i have the same problem except i do not hear a squeak when in gear driving....suscribed
Old 02-17-2008, 08:13 PM
dimwitrj's Avatar
BUMP
Old 02-17-2008, 09:23 PM
beanbag's Avatar
Default Re: Clutch squeak.. (dimwitrj)
Take off the slave cylinder and boot and look inside the transmission while the car is running. Without the slave cylinder in place, you can move the TOB away from the pressure plate such that it is not spinning at all.
To start the car, push down on the clutch interlock button underneath the pedal. DO NOT push the clutch pedal at any point with the slave cylinder off.
Old 02-18-2008, 02:09 AM
Dark@Powers's Avatar
Default Re: Clutch squeak.. (beanbag)
mine squeeks every once in a while too.
Old 02-18-2008, 10:47 AM
dimwitrj's Avatar
I highly doubt it's the slave itself because the squeaking is continuous. I'll try what beanbag said.
Mr.Death
Transmission & Drivetrain
03-09-2017 09:12 AM
stdefhatch
23
07-22-2007 12:04 PM
antivic
07-07-2006 05:57 PM
rough_draft
12-05-2004 09:01 PM
Philip
02-26-2004 02:41 PM
Quick Reply: Clutch squeak..
