clutch slave cylinder
Old 12-26-2005, 09:35 PM
RaceMyGhost's Avatar
Default clutch slave cylinder
my master clutch cylinder is starting to leak so it needs to be replaced, but how do i know if my clutch SLAVE cylinder needs to be replaced. i have 70,000miles on the car and a stage 2 clutch kit taking that into consideration.
Old 12-26-2005, 09:38 PM
PrinceAli132's Avatar
Default Re: clutch slave cylinder (RaceMyGhost)
Inspect the slave cylinder for any leakage, have you noticed any clutch pedal pressure problems, and feel the top of the clutch pedal for any fluid. I'm sure if you search around you probably could find other symptoms.
Ali
Old 12-26-2005, 09:51 PM
Default Re: clutch slave cylinder (PrinceAli132)
ive been looking around for sometime. clutch pedal is usually stiff as hell but i dont know if ive been getting used to the stiffness or its just the actual cylinder going bad. fluid is ok, there is some brake fluid drip stains though on my carpet in the car from the cylinder. and the slave cylinder, doesnt look like its leaking, just some normal engine bay dust and debree on it
PaulMc
05-18-2014 05:04 PM
dgerej2
10-01-2009 07:16 AM
RDAYA0
12-14-2006 05:31 PM
714JDMBB4
08-29-2005 05:34 PM
SloCivicHMM
05-12-2003 01:57 PM
Quick Reply: clutch slave cylinder
