clutch not engaging properly on teg...
I had this problem before where it would not go in gear and the pedal had no pressure to it. I changed the slave cylinder and it went away and the clutch pedal pressure was fine... now it did it again and I cant even get it into gear at all. Would this be the clutch master cylinder? even when I pump it I can not get any pressure.
thanks
mike
thanks
mike
Re: clutch not engaging properly on teg... (.RJ)
I have a clutchmaster stage 3 and it only has about less than 2500 miles on it... I broke it in properly and why would that have to do with no pressure in the clutch pedal?
thanks
mike
thanks
mike
i've had a spring come out of the friction disk before and still got pressure.
Too check if the clutch master cylinder is busted or not, go under the clutch pedal assembly and look for brake fluid on the floor.
If not, do as said above, bleed the system again.
Jos3ph
01-10-2006 07:38 PM
Nations Sickest CRX
08-30-2005 03:53 PM
