clutch engagment adjustment
Old 09-24-2008, 02:42 PM
boostedgsr1234's Avatar
Default clutch engagment adjustment
i just replaced my RPS pressure plate and sprung solid disk with a RPS sprung 4 puck disk and an act extreme plate. before my clutch engaged when the pedel was about 3" off the floor and now it engages when the pedel is just about all the way up. is this the way all act plates are? i have adjusted the pushrod on the master cylinder and tried bleeding the system, is there any other method of adjustment?
thanks
joe
Old 09-24-2008, 02:44 PM
BoSox46GSr's Avatar
Default Re: clutch engagment adjustment (boostedgsr1234)
They grab late, and hard. I think you're stuck with what you got. It will take some getting used to, but after a while, it feels normal.
Old 09-24-2008, 03:24 PM
thewrai6th's Avatar
The only adjustment is in the pedal, probably the pushrod you said you already adjusted. Possibly, you turned it the wrong way. I felt that way about my exedy 3 puck, but I got used to it.
Bleeding the system will actually make it stiffer and disengage sooner.
Old 09-24-2008, 06:09 PM
vinceg143's Avatar
i have a stock clutch and i just bleed them and it engages late also
[713]
06-20-2009 08:23 PM
InitialJRift
09-13-2006 10:43 AM
RTW DC2R
06-23-2006 07:42 AM
strsi
03-25-2006 04:55 PM
mashb16a
07-16-2002 09:06 PM
Quick Reply: clutch engagment adjustment
