Clutch engages and disengages VERY low....
Old 08-08-2007, 06:49 PM
hybridcrx's Avatar
Default Clutch engages and disengages VERY low....
96 GSR - hydraulic clutch.
Just put in a brand new pressure plate, full face clutch disc w/ 6 springs, throw out bearing, master clutch cylinder and slave clutch cylinder.
Everything works, but the clutch pedal itself sits about an inch lower than the gas and brake pedal and only has about 1 - 2" of total travel. It seems to cleanly engage / disengage and it shifts from gear to gear fine while driving. I can't pull the clutch pedal any further out even if I wanted to and after about 2" the pedal hits the floor.
Either way, it doesn't feel right - and quite frankly I don't like how it feels.
Is this normal? What can I change or what did I do wrong?
Old 08-08-2007, 07:08 PM
posHonda's Avatar
did you bleed the clutch after the install?
Old 08-09-2007, 07:12 AM
hybridcrx's Avatar
Default Re: (iVteC_PoWeR)
Yes, I bled the hydraulic system.
Anybody else?
Old 08-09-2007, 07:16 AM
immalooser's Avatar
Default Re: (hybridcrx)
did you adjust your clutch pedal?
http://www.team-integra.net/fo...ion=3
ac_attak
06-07-2006 11:12 AM
92BlackSi
10-26-2004 03:51 PM
LOC714
09-23-2004 12:34 PM
fiebru1119
04-08-2002 01:21 PM
MrSmith
09-28-2001 08:30 PM
Quick Reply: Clutch engages and disengages VERY low....
