Climate control buttons don't work???
Old 04-06-2012, 05:30 PM
Mkb897's Avatar
Default Climate control buttons don't work???
95' LS. Heater and A/C work, but won't switch to my feet or defroster? Does anyone know how to fix this?
Old 04-07-2012, 07:04 PM
TURBODC4TEG's Avatar
Default Re: Climate control buttons don't work???
might need a new climate control bud
Old 04-10-2012, 10:51 AM
spike32's Avatar
Usually the control with all the buttons break the same time. Meaning the control board as one piece. The ***** are a different component.
If the AC turns the compressor ON/OFF and you hear the recirc button move the flap, and the LED indicators work when you press the buttons, then I guess the control should be good. The next thing to check is the motor that moves the flap to control the air direction.
Old 04-10-2012, 12:11 PM
fcm
Old Fart
fcm's Avatar
Ditto the above, it will be the mode control motor or linkage from it, although it could still be the control head or wiring.
#4 is the mode control motor... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
You can stick you head up the drivers side of the dash and see if the motor moves when you press the mode buttons, check the black/yellow lead going to it, it should be a power lead, [ign. switch on] the black lead is a ground all the other leads come from the control head and are grounds when buttons are pressed...
Yellow/blue - defrost.
Yellow - heat/defrost.
Yellow/red - vents.
Green/yellow - Bi-Level.
Blue/white - heat.
Test the above leads for a ground when button pressed, test at the mode control motor plug. 94
Old 04-17-2012, 07:27 PM
Mkb897's Avatar
Thanks for all the helpful suggestions. Fixed it!! The problem was the circuit board. The solder gave out at each point where the green plug connected. I could wiggle it up and down and see the breaks in the solder. Fixed it with an iron and some solder. Warm feet
Bracy
Honda CR-V & Element
05-21-2019 03:20 PM
speedfreek128
02-19-2009 10:06 PM
xanonymousx
10-13-2007 05:57 AM
Echelon
01-23-2004 06:24 AM
VRD^don
09-17-2003 09:09 AM
Quick Reply: Climate control buttons don't work???
