check engine light
Old 03-19-2010, 08:16 PM
Swapped94's Avatar
Icon2 check engine light
i just put a new gauge cluster in and now check engine light is on. hooked it up to code reader and it shows p1336 and p1337 ignition module malfunction or misfire. i deleted the codes and they just come back. would this have anything to do with the new gauge cluster? any ideas on what to check
Old 03-19-2010, 08:32 PM
baller status's Avatar
Default Re: check engine light
No, that's your ECU. The gauge cluster is just lights. The codes are stored in the ECU.
Old 03-19-2010, 08:35 PM
Swapped94's Avatar
thats what i thought. what would cause that code to be thrown? any ideas what to check
Old 03-19-2010, 08:40 PM
TRIAL USER
Mr. Glove's Avatar
those check engine lights are killers -_-
Old 03-20-2010, 04:13 PM
imroadk1ll's Avatar
try resetting your ecu and see if it pops up again if not then try and get a reading again if nothing at all then nothing is wrong
Old 03-20-2010, 07:04 PM
Swapped94's Avatar
alright thanks ill try that in the morning. do i just unplug it for a couple minutes then plug it back in to reset it? sorry for the noob questions
Old 03-20-2010, 09:05 PM
imroadk1ll's Avatar
im assuming you have an obd2
P1336 CSF Sensor Intermittent Interruption
P1337 CSF Sensor No Signal
and yes a minute then plug back in. imma gonna look at my helms to see the problem
Old 03-20-2010, 10:02 PM
Sleepy.Bear's Avatar
Check out here:
http://www.team-integra.net/forum/di...TopicID=256887
That is a code that you want to get fixed asap! It will screw up your timing and your engine!!
DonnieG
03-08-2010 05:18 AM
90dteg
09-18-2008 12:54 PM
twinloop
12-28-2006 10:01 AM
jdm82
03-07-2006 01:08 PM
h kid
08-31-2005 10:14 PM
Quick Reply: check engine light
