Changing thermosat do i have to drain coolant
Old 10-18-2009, 07:37 PM
MrViet's Avatar
Default Changing thermosat do i have to drain coolant
Like title says, do i have to drain coolant in order to put my thermostat in?
Old 10-18-2009, 07:43 PM
follie gatts's Avatar
Default Re: Changing thermosat do i have to drain coolant
no. let your car warm up with the radiator cap off when you're done to let the air in the system bubble out.
Old 10-18-2009, 08:20 PM
rayzah_blade's Avatar
sooo, how is he to get to the thermostat, without taking off the radiator hose, since it will still be filled with coolant???.....
Old 10-19-2009, 03:58 AM
some of it is bound to escape, but there is no point in removing the radiator drain plug or even the block drain bolt. neither of which, by the way, would remove all the coolant from the hose you are talking about anyway.
Old 10-19-2009, 05:03 AM
Daisy... Daisy...
Dogginator's Avatar
You have to drain the coolant below the housing. Since your thermostat is bad (stuck open) the coolant will drain just fine. It would drain just fine with the weep hole anyway.
Old 10-19-2009, 09:09 AM
this statement leads me to believe that you have never removed the thermo, possibly even changed your coolant.. the thermostat is located in spot where there is coolant heavily populating the areas surrounding it, and removing the hose leading to the thermo will most definitely allow coolant to pour all over the place, essentially draining the coolant anyways.. I suppose if there was only a quart in the system, there may not be a need to drain, but if your running your car with only a quart of coolant there are bigger issues at stake.
Old 10-19-2009, 10:35 AM
Mattb16teg's Avatar
Technically, yes you should, on the fly I have done it many times without doing so and letting coolant drain into a pan once I unbolt the housing.
Old 10-19-2009, 01:51 PM
MrViet's Avatar
thank you all very much. so conclusion is that i don't have to flush coolant. thank you.
Old 10-19-2009, 02:46 PM
Mattb16teg's Avatar
No, is that you should, if you do not coolant will go everywhere!
Old 10-19-2009, 04:06 PM
hybrid90's Avatar
You technically don't have to. I just used a pan to collect the coolant that's spilled out a lil (if not done right.. it might get a lil messy).. but I mean.. while you're at it.. you might as well just change everything fresh and new.
Old 10-19-2009, 04:08 PM
Daisy... Daisy...
Dogginator's Avatar
Not draining coolant = a big mess
Draining coolant = a little mess
Choose wisely.
Old 10-19-2009, 04:16 PM
steveo135's Avatar
would probably be healthy for the car.. when was the last time coolant was flushed.. if it was recently I would say just let whatever comes out, come out and refill as needed.. as dogg said will be messy though
Old 10-19-2009, 05:21 PM
vladd's Avatar
i went with "big mess" when i did mine. it's a pretty quick job if you don't take the time to drain it.
Old 10-19-2009, 08:24 PM
dothacker's Avatar
when i changed my thermostat, i drained all my coolant and changed my fan switch too while i'm working on the same area.
Old 10-19-2009, 09:45 PM
ORLY do you want picture proof? do you want me to scan my thermostat and radiator barn receipts? maybe i'll go outside and put a level between the thermostat housing and the radiator, and then we can debate how much coolant is below that level depending on the pitch of my driveway and barometer pressure.
Old 10-20-2009, 03:41 AM
Daisy... Daisy...
Dogginator's Avatar
The coolant will drain with the thermostat installed. I have done this many times before. You just have to wait a bit. The exception would be if the thermostat was physically clogged.
Old 10-20-2009, 05:42 PM
yes, you will need to do exactly that.
Old 10-20-2009, 09:43 PM
STRDAGEY88's Avatar
I changed my thermostat last week without draining the coolant... but when you pull the hose off coolant is going to come out of the hose. Also when you pull the thermostat coolant is going to start draining from behind it. So basically if you can get the old thermostat out and put the new one in quickly you should be fine. I learned this the hard way. have an oil pan or something to collect under the car
whiteGSR
07-26-2022 03:06 PM
Rvu
01-29-2010 08:15 AM
KHowe
07-21-2008 11:02 AM
R249
01-24-2003 04:17 AM
magic hat #9
08-24-2002 08:46 PM
Quick Reply: Changing thermosat do i have to drain coolant
