Car wont start, please help
ok....heres the scoop, the car will turn over, but it wont start. What happend was i had shut my car off for the night, it had been running fine all day, i went to start it the next morning and thats when the problem had started. The car is getting both air and fuel but is not getting a spark from the coil, so my first thought is that the coil is bad...so i check the coil it had the right resistences/voltages...so i checked the wiring from the coil to the comp, its fine, checked the Ignition Control Modual, its fine, i checked the Main relay switch, its fine, and i have run out of things to check, i have looked at all the fuses, all the relays, i have checked all the connections under the hood, and im at a loss...if anyone has any advice and they can help, please do
Re: Car wont start, please help (94_CRVtec)
Try changing the distributor. I can guarantee that your problem is with your ignitor. I change mine every two years due to the MSD set-up. The MSD tends to burn out the ignitor prematurely.
Re: Car wont start, please help (Hulkdon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulkdon1 »</TD></TR><TR><TD CLASS="quote">Try changing the distributor. I can guarantee that your problem is with your ignitor. I change mine every two years due to the MSD set-up. The MSD tends to burn out the ignitor prematurely.</TD></TR></TABLE>
yeah.. i think thats where your problem is.. it happened to me too..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_CRVtec »</TD></TR><TR><TD CLASS="quote">...so i check the coil it had the right resistences/voltages...</TD></TR></TABLE>Resistance isn't the only way for a coil to fail. Unless you have a meggar, you can't easily check for insulation breakdown in the coil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_CRVtec »</TD></TR><TR><TD CLASS="quote">... checked the Ignition Control Modual, its fine...</TD></TR></TABLE>How did you test the ignitor (ICM)?
slikz714
04-27-2009 03:18 AM
